0.107 is still in beta. So you should be discussing this on the beta discord.
Also your post is very confusing. It sounds like you are recommending people delete all their groups. This is not required. Only the depreciated options and services relating to the old SatesUI need to be removed.
Groups - Groups are NOT being removed, but the configuration options, services, and service options related to the (previously deprecated and now removed) States UI are now removed in this release. This includes:
The view and control configuration options for a group.
The group.set_visibility service call
The control , visible , view options on the group.set service callPlease ensure your configuration and automations do not use these anymore. - (@frenck - #32021) (group docs)
0.107 has not yet been released. You upgraded to a beta version that is going to have issues that will be corrected before general release.
No, you are confusing people with a very unclear post. What did you actually delete? It is not at all clear from your post. Did you delete all your groups or did you only delete the depreciated services and options?
I have no idea what this means.
The breaking changes will be documented clearly (unlike your post) when the next version is released.
Hello, I used groups as well for my automations. E.g.swich off all lights or closing my cover. Now, with the Version 107 I can’t see my groups. What could be my alternative? How can I use he groups for my automations?
