I’ve done some reading and as I understand it, something broke with time. Since all my automations broke anyway, I figured I might as well use this as an opportunity to clean those up.
I am however confused about it. For example, this one turned off a light automatically 5 minutes after it was turned on, and it no longer works.
- id: '1545329806286'
alias: Basement Light Auto Off
- entity_id: light.basement
for: 00:05:00
platform: state
to: 'on'
condition: []
- data:
service: light.turn_off
I’m confused, is the ‘for’ part a different syntax now, or do I have to add something to my config? I also don’t understand why ALL of my automations broke, when only a small percentage used any sort of time or timer function.
all don’t show up
this is what I am seeing in the logs
2019-01-24 14:03:32 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of switch. Setup failed for dependencies: group
2019-01-24 14:03:32 ERROR (MainThread) [homeassistant.setup] Setup failed for switch: Could not set up all dependencies.
2019-01-24 14:03:32 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of automation. Setup failed for dependencies: group
2019-01-24 14:03:32 ERROR (MainThread) [homeassistant.setup] Setup failed for automation: Could not set up all dependencies.
2019-01-24 14:03:32 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of light. Setup failed for dependencies: group
2019-01-24 14:03:32 ERROR (MainThread) [homeassistant.setup] Setup failed for light: Could not set up all dependencies.
2019-01-24 14:03:32 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of cover. Setup failed for dependencies: group
2019-01-24 14:03:32 ERROR (MainThread) [homeassistant.setup] Setup failed for cover: Could not set up all dependencies.
2019-01-24 14:03:32 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of script. Setup failed for dependencies: group
2019-01-24 14:03:32 ERROR (MainThread) [homeassistant.setup] Setup failed for script: Could not set up all dependencies.
2019-01-24 14:03:32 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of device_tracker. Setup failed for dependencies: group
2019-01-24 14:03:32 ERROR (MainThread) [homeassistant.setup] Setup failed for device_tracker: Could not set up all dependencies.
2019-01-24 14:03:33 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of fan. Setup failed for dependencies: group
2019-01-24 14:03:33 ERROR (MainThread) [homeassistant.setup] Setup failed for fan: Could not set up all dependencies.
2019-01-24 14:03:33 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of lock. Setup failed for dependencies: group
2019-01-24 14:03:33 ERROR (MainThread) [homeassistant.setup] Setup failed for lock: Could not set up all dependencies.
2019-01-24 14:03:33 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of ios. Setup failed for dependencies: device_tracker
2019-01-24 14:03:33 ERROR (MainThread) [homeassistant.setup] Setup failed for ios: Could not set up all dependencies.
