Stoke of genius, this worked for me. Cheers mate!
It worked for me too⌠domain amazon.it
thanks for that. it works fine!
no sound output on my device
Thanks. That worked for me. All device available.
Use your file code editor. Open Alexa_media, then open the manifest.json file.
Thanks so much. That worked for me !!!
Same here, not getting any errors but Alexa devices showing unavailable.
Iâm also getting all devices unavailable
As mentioned below my original post, this worked but devices donât respond. Some entities show unavailable and all devices show âstandbyâ. Automations with actions that announce to an Alexa media player complete as successful but no announcement is played over the target device.
Hi there! At today, with latest update seems to work correctly. I have reloaded the integration, relogin from restart and the devices now are working. The automations have been relinked well.
The only thing doesnât still work is the temperature. I hope it will be fixed soon
Thank you!
For those still having problems:
All my alexa devices disappeared after the HA 2024-8 update, how I solved it:
- I went back to the last backup;
- Updated again to 2024-8;
- Updated Alexa integration to 4.12.7;
- I clicked on reconfigure Alexa.
Now everything is working.
Worked for me also.
Hi all
After the upgrade I get this error - what is the solution to this?
All the details I fill in are correct
Try changing "alexapy==1.28.2"
to "alexapy>=1.28.2"
, then reload.
Iâll try, but sorry for the question⌠itâs the same version number, what does it give?
Try changing "alexapy== xxx to
âalexapy=1.28.2â` , then reload.
Itâs not the version number which is causing you an issue this time. Itâs the symbols right before it.
Try >=
instead of ==
, like you have next to packaging
and wrapt
