Hi all,
I am trying to upgrade Home Assistant with a shellscript
ha_update: pip3 install homeassistant=={{ states.sensor.ha_version_latest }}
Then I run from the UI:
shell_command.ha_update
But this throws me an error
Error running command: `pip3 install homeassistant=={{ states.sensor.ha_version_latest }}`, return code: 1
NoneType: None
The sensor is populated by a MQTT command:
So am I doing something wrong or is that approach in general doable?
Thanks for all hints.
Br
