UPnP/IGD Errors
Hi
Can someone help me with this UPnP errors. I have never put it as a sensor but still piles up my log.
2019-04-25 20:14:52 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry UPnP/IGD for upnp
  File "/usr/src/app/homeassistant/config_entries.py", line 309, in async_setup
    hass, self)
  File "/usr/src/app/homeassistant/components/upnp/__init__.py", line 132, in async_setup_entry
    config_entry.data.get('udn'))
  File "/usr/src/app/homeassistant/components/upnp/__init__.py", line 102, in async_discover_and_construct
    return await Device.async_create_device(hass, ssdp_description)
  File "/usr/src/app/homeassistant/components/upnp/device.py", line 63, in async_create_device
    upnp_device = await factory.async_create_device(ssdp_description)
  File "/usr/local/lib/python3.7/site-packages/async_upnp_client/client_factory.py", line 50, in async_create_device
    root = await self._async_get_url_xml(description_url)
  File "/usr/local/lib/python3.7/site-packages/async_upnp_client/client_factory.py", line 278, in _async_get_url_xml
    await self.requester.async_http_request('GET', url)
  File "/usr/local/lib/python3.7/site-packages/async_upnp_client/client.py", line 70, in async_http_request
    body_type=body_type)
  File "/usr/local/lib/python3.7/site-packages/async_upnp_client/aiohttp.py", line 109, in async_do_http_request
    resp_body = await response.text()
  File "/usr/local/lib/python3.7/site-packages/aiohttp/client_reqrep.py", line 1010, in text
    return self._body.decode(encoding, errors=errors)  # type: ignore
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xf0 in position 493: invalid continuation byte
Also I have ignored it in the discovery section i.e.
discovery:
 ignore:
 - igd
But the errors keep on coming
Have you deleted any related integrations on the Configuration/Integrations page which may have been created before you ignored igd discovery? Did the trick for me.
thanks that done it
Got a TP-LInk Deco M5 (1 module) and it was discovered by HA. But when HA reboot I get those errors:
Never used the UPnP/IDG so nothing left in configuration file.
2019-12-11 11:35:29 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.m5_bytes_received fails
  File "/usr/local/lib/python3.7/site-packages/async_upnp_client/aiohttp.py", line 103, in async_do_http_request
    async with self._session.request(method, url, headers=headers, data=body) as response:
  File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 1012, in __aenter__
    self._resp = await self._coro
  File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 483, in _request
    timeout=real_timeout
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 523, in connect
    proto = await self._create_connection(req, traces, timeout)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 859, in _create_connection
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 986, in _create_direct_connection
    req=req, client_error=client_error)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 936, in _wrap_create_connection
    return await self._loop.create_connection(*args, **kwargs)  # type: ignore  # noqa
  File "uvloop/loop.pyx", line 1964, in create_connection
  File "uvloop/loop.pyx", line 1951, in uvloop.loop.Loop.create_connection
concurrent.futures._base.CancelledError
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 270, in async_update_ha_state
    await self.async_device_update()
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 448, in async_device_update
    await self.async_update()
  File "/usr/src/homeassistant/homeassistant/components/upnp/sensor.py", line 144, in async_update
    self._state = await self._device.async_get_total_bytes_received()
  File "/usr/src/homeassistant/homeassistant/components/upnp/device.py", line 152, in async_get_total_bytes_received
    return await self._igd_device.async_get_total_bytes_received()
  File "/usr/local/lib/python3.7/site-packages/async_upnp_client/profiles/igd.py", line 89, in async_get_total_bytes_received
    result = await action.async_call()
  File "/usr/local/lib/python3.7/site-packages/async_upnp_client/client.py", line 509, in async_call
    await self.service.requester.async_http_request('POST', url, headers, body)
  File "/usr/local/lib/python3.7/site-packages/async_upnp_client/aiohttp.py", line 113, in async_do_http_request
    resp_body = None
  File "/usr/local/lib/python3.7/site-packages/async_timeout/__init__.py", line 55, in __aexit__
    self._do_exit(exc_type)
  File "/usr/local/lib/python3.7/site-packages/async_timeout/__init__.py", line 92, in _do_exit
    raise asyncio.TimeoutError
concurrent.futures._base.TimeoutError
2019-12-11 11:35:29 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.m5_packets_sec_sent fails
  File "/usr/src/homeassistant/homeassistant/components/upnp/sensor.py", line 200, in async_update
    new_value = await self._async_fetch_value()
  File "/usr/src/homeassistant/homeassistant/components/upnp/sensor.py", line 256, in _async_fetch_value
    return await self._device.async_get_total_packets_sent()
  File "/usr/src/homeassistant/homeassistant/components/upnp/device.py", line 165, in async_get_total_packets_sent
    return await self._igd_device.async_get_total_packets_sent()
  File "/usr/local/lib/python3.7/site-packages/async_upnp_client/profiles/igd.py", line 120, in async_get_total_packets_sent
    resp_body = None
2019-12-11 11:35:29 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.m5_kbyte_sec_received fails
  File "/usr/src/homeassistant/homeassistant/components/upnp/sensor.py", line 230, in _async_fetch_value
    return await self._device.async_get_total_bytes_received()
    resp_body = None
2019-12-11 11:35:29 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.m5_packets_sec_received fails
  File "/usr/src/homeassistant/homeassistant/components/upnp/sensor.py", line 254, in _async_fetch_value
    return await self._device.async_get_total_packets_received()
  File "/usr/src/homeassistant/homeassistant/components/upnp/device.py", line 161, in async_get_total_packets_received
    return await self._igd_device.async_get_total_packets_received()
  File "/usr/local/lib/python3.7/site-packages/async_upnp_client/profiles/igd.py", line 110, in async_get_total_packets_received
    resp_body = None
2019-12-11 11:35:29 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.m5_packets_sent fails
  File "/usr/src/homeassistant/homeassistant/components/upnp/sensor.py", line 150, in async_update
    self._state = await self._device.async_get_total_packets_sent()
    resp_body = None
2019-12-11 11:35:29 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.m5_kbyte_sec_sent fails
  File "/usr/src/homeassistant/homeassistant/components/upnp/sensor.py", line 232, in _async_fetch_value
    return await self._device.async_get_total_bytes_sent()
  File "/usr/src/homeassistant/homeassistant/components/upnp/device.py", line 156, in async_get_total_bytes_sent
    return await self._igd_device.async_get_total_bytes_sent()
  File "/usr/local/lib/python3.7/site-packages/async_upnp_client/profiles/igd.py", line 99, in async_get_total_bytes_sent
    resp_body = None
2019-12-11 11:35:29 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.m5_packets_received fails
  File "/usr/src/homeassistant/homeassistant/components/upnp/sensor.py", line 148, in async_update
    self._state = await self._device.async_get_total_packets_received()
    resp_body = None
2019-12-11 11:35:29 ERROR (MainThread) [homeassistant.helpers.entity] Update for sensor.m5_bytes_sent fails
  File "/usr/src/homeassistant/homeassistant/components/upnp/sensor.py", line 146, in async_update
    self._state = await self._device.async_get_total_bytes_sent()
    resp_body = None
