techbw
(Stephen Van Rooyen)
February 20, 2019, 4:07pm
1
I have just installed home assistant and when I went to integration and clicked UPNP/IGD it added a whole lot of info from the router.
I went to entities and removed them one by one, and then disabled UPNP/IGD but the sensors now just show as not found.
How can I remove them completly.
I have looked through all the yaml files and can’t seem to find where the data is stored.
jcastro
(Jonatan)
February 20, 2019, 4:10pm
2
Should be on known_devices.yaml and then restart Home Assistant
tom_l
February 20, 2019, 4:12pm
3
Delete the integration if you are no longer using it (top right trash icon on the UPNP integration page). That should remove them.
techbw
4
I have done that, but have the icons in image that remain.
techbw
February 20, 2019, 4:15pm
5
where can I find the known_devices.yaml file, as this is not in homeassistant directory
Yaml Files in the HA directory
automations.yaml
configurations.yaml
customize.yaml
groups.yaml
scripts.yaml
secrets.yaml
No known_devices.yaml
oh it’s on HA version 0.87.1
jcastro
(Jonatan)
February 21, 2019, 6:24pm
6
Umm weird! it should be right in your config folder together with the configuration.yaml, etc.
Add this your configuration.yaml
discovery:
ignore:
- igd
techbw
February 21, 2019, 8:08pm
8
Thanks,
I have done a clean install again, and just didn’t start the igp this time.
Thanks for the response, should it happen again, I now know where to change it.
Thanks again.
techbw
February 21, 2019, 8:09pm
9
Have just done a clean install again, and known_devices.yaml is still not in the folder, but the clean install has resolved my issue, I just won’t auto configure igp
techbw
February 21, 2019, 9:29pm
10
Found where the “badges” at the top of the screen are edited.
Top right of Overview the burger menu …
Then Configure UI
Burger Menu again at top right
Raw Config Editor
under the badges section there is a list of badge entities that can be edited.
Found this accidentally \o/
