These are Tripp-Lite units
Posting this kind of thing (especially in the âshare your projectsâ section) is completely useless without the associated code to accomplish it.
is it just the cards in lovelace using pre-existing integrations/entities or do you use a new integration?
Sorry about that.
Itâs just snmp sensors done according to docs. I used a windows program called âmiblle browserâ to figure out what OIDs I was looking for.
I use sensor: !include_dir_merge_list sensors in my config, and so I drop this yaml file into the sensors folder:
- platform: snmp
host: tripplite2.mydomain.net
version: 2c
community: tripplite
baseoid: .1.3.6.1.2.1.33.1.2.7.0
unit_of_measurement: "°C"
name: "UPS2 battery temperature"
- platform: snmp
version: 2c
unit_of_measurement: "V"
name: "UPS2 battery Voltage"
- platform: snmp
version: 2c
baseoid: .1.3.6.1.2.1.33.1.2.4.0
unit_of_measurement: "%"
name: "UPS2 battery charge remaining"
- platform: snmp
version: 2c
unit_of_measurement: "degrees"
- platform: snmp
version: 2c
baseoid: 1.3.6.1.2.1.33.1.2.3.0
unit_of_measurement: "minutes"
name: "UPS2 runtime minutes remaining"
- platform: snmp
version: 2c
baseoid: .1.3.6.1.2.1.33.1.3.3.1.3.1
name: "UPS2 AC Input Voltage"
- platform: snmp
version: 2c
baseoid: .1.3.6.1.2.1.33.1.4.4.1.2.1
name: "UPS2 output voltage"
- platform: snmp
version: 2c
baseoid: .1.3.6.1.2.1.33.1.4.4.1.4.1
unit_of_measurement: "W"
name: "UPS2 output load"
- platform: snmp
version: 2c
baseoid: 1.3.6.1.4.1.850.1.1.3.1.3.1.5.1.2.1.1
unit_of_measurement: "C"
name: "UPS2 Battery Temperature"
value_template: '{{ ((value | int) / 100) | int}}'
- platform: snmp
version: 2c
baseoid: 1.3.6.1.4.1.850.1.1.3.1.3.1.1.1.1.1
name: "UPS2 battery status"
value_template: >
{% if value | int == 1 %}
unknown
{% elif value | int == 2 %}
Normal
{% elif value | int == 3 %}
BatteryLow
{% elif value | int == 4 %}
BatteryDepleted
{% else %}
commfail
{% endif %}
- platform: snmp
version: 2c
baseoid: 1.3.6.1.4.1.850.1.1.3.1.3.1.2.1.4.1
name: "UPS2 battery charge detail"
value_template: >
{% if value | int == 0 %}
float
{% elif value | int == 1 %}
charging
resting
discharging
normal
{% elif value | int == 5 %}
standby
{% else %}
commfail
{% endif %}
- platform: snmp
version: 2c
baseoid: 1.3.6.1.4.1.850.1.1.3.1.3.3.1.1.1.1
value_template: >
unknown
other
none
AC Input
bypass
battery
{% elif value | int == 6 %}
boosting
{% elif value | int == 7 %}
reducing
{% elif value | int == 8 %}
second
{% elif value | int == 9 %}
economy
{% else %}
commfail
{% endif %}
The lovelace config for each column looks like this:
type: vertical-stack
title: MAIN RACK UPS 1
cards:
- type: picture-elements
image: /local/images/tripplite.png
elements:
- type: state-label
entity: sensor.ups1_ac_input_voltage
style:
top: 40%
left: 84%
font-size: 18px
font-family: fantasy
background-color: green
padding: none
- type: state-label
entity: sensor.ups1_source
style:
top: 30%
left: 18%
font-size: 18px
font-family: monospace
- type: 'custom:bar-card'
entities:
- entity: sensor.ups1_battery_charge_remaining
direction: right
icon: 'mdi:battery'
color: green
positions:
icon: 'off'
indicator: 'off'
value: inside
severity:
height: 20px
- type: glance
title: Battery Status
entities:
- entity: sensor.ups1_battery_status
icon: 'mdi:battery-heart-variant'
- entity: sensor.ups1_runtime_minutes_remaining
icon: 'mdi:battery-alert-variant-outline'
- entity: sensor.ups1_battery_charge_detail
icon: 'mdi:battery-charging'
- entity: sensor.ups1_battery_temperature
- entity: sensor.ups1_source
state_color: false
show_state: true
show_icon: true
show_name: true
- type: horizontal-stack
cards:
- type: gauge
min: 0
max: 100
- type: gauge
entity: sensor.ups1_battery_voltage
min: 10
max: 30
cards:
- type: gauge
min: 0
max: 50
- type: gauge
min: 100
max: 130
cards:
- type: gauge
entity: sensor.ups1_output_voltage
min: 100
max: 130
- type: gauge
entity: sensor.ups1_output_load
min: 0
max: 2000
- type: 'custom:mini-graph-card'
entities:
name: Charge Remaining (1hr)
show_legend: true
icon: 'mdi:battery-alert'
hours_to_show: 1
points_per_hour: 30
lower_bound: 0
upper_bound: 100
animate: true
show:
labels: true
points: hover
state: false
entities:
- entity: sensor.ups1_output_load
name: Output Load (1hr)
show_legend: true
icon: 'mdi:power-plug'
hours_to_show: 1
points_per_hour: 600
line_width: 2
smoothing: false
animate: true
show:
labels: true
points: false
extrema: true
state: false
Thank you for posting this information @VinistoisR !
Tripp Liteâs OID doc can be found at this URL: https://assets.tripplite.com/flyer/supported-snmp-oids-technical-application-bulletin-en.pdf
Thanks @VinistoisR, I tried this but no luck as there must be other custom integrations or sensor definitions, since after using your YAML code none of the sensors are available/visible for my SNMP enabled Tripp Lite UPS.
Any chance you can post more detailed instructions and code? Much appreciated.
Hereâs what Iâm using with my TrippLite:
- platform: snmp
host: poweralert-061036777249
# host: 10.0.1.7
version: 2c
baseoid: .1.3.6.1.4.1.850.1.1.3.1.2.1.1.8.1
unit_of_measurement: "°F"
name: "UPS ambient temperature"
value_template: '{{ (value | int) / 10 }}'
- platform: snmp
host: 10.0.1.7
version: 2c
name: "UPS output power"
- platform: snmp
host: <<replace with your own UPS IP address>>
version: 2c
value_template: >
unknown
other
none
AC Input
bypass
battery
boosting
reducing
second
economy
{% else %}
commfail
{% endif %}
Just an hint:
use this app (as suggested) to discover codes
setup properly the app
import this database of codes
make a query to the device (subtree, top right list) of the entire UPS list.
Grab your values!
To test the connection, use this one : â.1.3.6.1.2.1.1.1.0â who is sysDescr, should work with every device.
Thank you theyâre working great.
I would like some help to add the total energy consumed by the Tripplite in my Energy dashboard.
I think the sensor that has this information is the sensor.output_load sensor.
Unfortunately it seems like itâs not compatible with the Energy dashboard as it canât be found there.
I think that I must create a Riemann sum integral sensor but I donât know what to put in there.
If anyone could help me on this one it would be very much appreciated.
