Anybody else order a ton of crap through amazon and/or other such services? Thinking something similar to https://home-assistant.io/components/sensor.usps/ that could be used with your My Choice UPS account to notify you of approximate package arrival times etc.
This is currently already possible with the imap email content sensor with a little templating.
That said, something built in would be simpler, provided it is easy to set up. I think the new USPS sensor works by scraping the web interface, so it wouldnât likely be easy to adapt to the UPS site.
UPS does offer its own API.
Shippo offers a single API for multiple shippers. It might be another option for this. Havenât dug into the docs too deeply yet.
I found a few other projects on github, but most havenât been updated in awhile.
Unlikely to happen currently as UPS doesnât have an API for My Choice.
Will this be integrated into the next release? Or does this need to be manually imported? New to HA
Next release.
Hey, Just tried using the UPS Sensor, but getting the following error, any ideas?
17-04-26 16:51:11 ERROR (MainThread) [homeassistant.setup] Not initializing sensor.ups because could not install dependency upsmychoice==1.0.2
17-04-26 16:51:11 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.ups: Could not install all requirements.
From in your virtualenv, try pip install upsmychoice==1.0.2
No luck.
pip3 install upsmychoice==1.0.2
Downloading/unpacking upsmychoice==1.0.2
Downloading upsmychoice-1.0.2.tar.gz
Running setup.py (path:/tmp/pip-build-fspkp1kr/upsmychoice/setup.py) egg_info for package upsmychoice
Downloading/unpacking beautifulsoup4==4.5.1 (from upsmychoice==1.0.2)
Downloading beautifulsoup4-4.5.1-py3-none-any.whl (83kB): 83kB downloaded
Downloading/unpacking python-dateutil==2.6.0 (from upsmychoice==1.0.2)
Downloading python_dateutil-2.6.0-py2.py3-none-any.whl (194kB): 194kB downloaded
Downloading/unpacking requests==2.12.4 (from upsmychoice==1.0.2)
Downloading requests-2.12.4-py2.py3-none-any.whl (576kB): 576kB downloaded
Requirement already satisfied (use --upgrade to upgrade): six>=1.5 in /usr/lib/python3/dist-packages (from python-dateutil==2.6.0->upsmychoice==1.0.2)
Installing collected packages: upsmychoice, beautifulsoup4, python-dateutil, requests
Running setup.py install for upsmychoice
error: could not create '/usr/local/lib/python3.4/dist-packages/upsmychoice': Permission denied
Complete output from command /usr/bin/python3 -c "import setuptools, tokenize;__file__='/tmp/pip-build-fspkp1kr/upsmychoice/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-fufqdpfi-record/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
creating build/lib
creating build/lib/upsmychoice
copying upsmychoice/__init__.py -> build/lib/upsmychoice
running install_lib
creating /usr/local/lib/python3.4/dist-packages/upsmychoice
Cleaning up...
Command /usr/bin/python3 -c "import setuptools, tokenize;__file__='/tmp/pip-build-fspkp1kr/upsmychoice/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-fufqdpfi-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip-build-fspkp1kr/upsmychoice
Storing debug log for failure in /home/pi/.pip/pip.log
Youâre not in your virtualenv. Note how itâs installing to your system python site packages.
Iâm not in a virtualenv
Then youâll have to switch to a superuser
I am logged in as the only user = pi
If it matters, running Home Assistant on Raspberry Pi using HASSbian
Upgraded Hassbian, now get the following Error:-
17-04-28 14:32:36 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform ups
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 155, in _async_setup_platform
entity_platform.schedule_add_entities, discovery_info
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/sensor/ups.py", line 44, in setup_platform
import upsmychoice
File "/home/homeassistant/.homeassistant/deps/upsmychoice/__init__.py", line 4, in <module>
from json.decoder import JSONDecodeError
ImportError: cannot import name 'JSONDecodeError'
Im getting the exact same error. Did you get it figured out?
Sorry, no, I ended up removing it from HASS.
Were you able to get this working?
nope and even todays update to 0.46 doesnt seem to do the trick either. Not sure whats wrong but i get this error still
2017-06-04 15:03:50 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform ups
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 160, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File "/usr/lib/python3.4/asyncio/tasks.py", line 372, in wait_for
return fut.result()
import upsmychoice
File "/home/homeassistant/.homeassistant/deps/upsmychoice/__init__.py", line 7, in <module>
Thatâs the same error I get.
I tried upgrading to 0.46, but no go, HASS wonât load after upgrade, reverted back to 0.45.1.
