I have the same UPS. How did you setup the UPS to communicate with HA?
I currently just have my UPS connected with USB to a NAS-server so it can shutdown safely, but I’d like to monitor it in HA and use this card.
Network UPS tools (NUT) most likely. It’s compatible with most major manufacturers. Look in addons if you are running HAOS. Otherwise search online for NUT
sorry for the late reponse, but here it is:
####### APC UPS 2200 Network card 9630 ######
- platform: snmp
host: 192.168.178.12
baseoid: 1.3.6.1.4.1.318.1.1.1.2.2.1.0
accept_errors: true
unit_of_measurement: '%'
- platform: snmp
baseoid: 1.3.6.1.4.1.318.1.1.1.2.2.3.0
accept_errors: true
value_template: >-
{% set time = (value | int) / 100 | int %}
{% set minutes = ((time % 3600) / 60) | int %}
{% set hours = ((time % 86400) / 3600) | int %}
{% set days = (time / 86400) | int %}
{%- if time < 60 -%}
Less than a minute
{%- else -%}
{%- if days > 0 -%}
{{ days }}d
{%- endif -%}
{%- if hours > 0 -%}
{%- if days > 0 -%}
{%- endif -%}
{{ hours }}h
{%- endif -%}
{%- if minutes > 0 -%}
{%- if days > 0 or hours > 0 -%}
{%- endif -%}
{{ minutes }}m
{%- endif -%}
{%- endif -%}
- platform: snmp
baseoid: 1.3.6.1.4.1.318.1.1.1.4.2.3.0
accept_errors: true
- platform: snmp
baseoid: 1.3.6.1.4.1.318.1.1.1.2.2.2.0
accept_errors: true
unit_of_measurement: '°C'
- platform: snmp
baseoid: 1.3.6.1.4.1.318.1.1.1.2.2.4.0
accept_errors: true
value_template: >-
{%if value == '1' %}
Good
{% elif value == '2' %}
Failed
{% endif %}
- platform: snmp
baseoid: 1.3.6.1.4.1.318.1.1.1.1.1.1.0
accept_errors: true
- platform: snmp
baseoid: 1.3.6.1.4.1.318.1.1.1.3.2.1.0
accept_errors: true
unit_of_measurement: 'V'
- platform: snmp
baseoid: 1.3.6.1.4.1.318.1.1.1.3.2.5.0
accept_errors: true
value_template: >-
No events
High line voltage
{% elif value == '3' %}
Brownout
{% elif value == '4' %}
Loss of mains power
{% elif value == '5' %}
Small temporary power drop
{% elif value == '6' %}
Large temporary power drop
{% elif value == '7' %}
Small spike
{% elif value == '8' %}
Large spike
{% elif value == '9' %}
UPS self test
{% elif value == '10' %}
Excessive input voltage fluctuation
{% endif %}
- platform: snmp
accept_errors: true
- platform: snmp
baseoid: 1.3.6.1.4.1.318.1.1.1.4.2.4.0
accept_errors: true
unit_of_measurement: 'A'
- platform: snmp
baseoid: 1.3.6.1.4.1.318.1.1.1.7.2.3.0
accept_errors: true
value_template: >-
OK
Failed
Invalid Test
Test In Progress
{% endif %}
- platform: snmp
baseoid: 1.3.6.1.4.1.318.1.1.1.7.2.4.0
accept_errors: true
- platform: snmp
baseoid: 1.3.6.1.4.1.318.1.1.1.8.1.0
accept_errors: true
value_template: >-
on
off
{% endif %}
- platform: snmp
baseoid: 1.3.6.1.4.1.318.1.1.1.4.1.1.0
accept_errors: true
value_template: >-
Unknown
On Line
On Battery
On Smart Boost
Timed Sleeping
Software Bypass
Off
Rebooting
Switched Bypass
Hardware Failure Bypass
{% elif value == '11' %}
Sleeping Until Power Returns
{% elif value == '12' %}
On Smart Trim
{% endif %}
I have an issue.
I installed all dependencies, I replaced all of mine entities, but nothing is shown even an error:
Any suggestion?
Marco
Hard to give any suggestions since you have not posted a code.
You are rigth, sorry.
Here it is:
type: custom:config-template-card
variables:
- states[''sensor.ups1500_status''].state
- states[''sensor.ups1500_battery_level''].state
- states[''sensor.ups1500_load''].state
- states[''sensor.ups1500_line_voltage''].state
- states[''sensor.ups1500_battery_voltage''].state
entities:
- sensor.ups1500_status
- sensor.ups1500_battery_level
- sensor.ups1500_load
- sensor.ups1500_line_voltage
- sensor.ups1500_battery_voltage
card:
type: entities
show_header_toggle: 'off'
style: |
.card-header {
padding: 0px 0px 0px 0px !important;
entities:
- type: section
style: |
.label {
text-align: center !important;
margin-left: 0px !important;
font-size: 17px !important;
label: ${ 'APC --- ' + vars[0] + ' --- ' + vars[1] }
- type: custom:hui-element
card_type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: picture
style: |
ha-card {
--paper-card-background-color: 'rgba(0, 0, 0, 0.0)';
--ha-card-background: "rgba(0, 0, 0, 0.0)";
--ha-card-box-shadow: 'none';
image: /local/wifi-guest.png
- type: custom:button-card
layout: icon_name_state2nd
show_icon: true
show_state: true
styles:
grid: null
card:
- '--ha-card-background': rgba(0, 0, 0, 0.0)
- '--ha-card-box-shadow': none
icon:
- padding: 10px 0px 0px
- height: 40px
- width: 40px
state:
- justify-self: start
- font-family: Roboto, sans-serif
- font-size: 14px
name:
- padding: 20px 0px 0px
entity: sensor.ups1500_runtime_left
icon: mdi:battery-high
cards:
- type: custom:bar-card
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
--paper-item-icon-color: 'var(--text-primary-color)';
bar-card-name {
margin-left: -10px;
entity: sensor.ups1500_battery_level
entity_row: true
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
bar-card-name {
margin-left: -10px;
entity: sensor.ups1500_load
entity_row: true
- type: entities
entities:
- entity: sensor.ups1500_line_voltage
icon: mdi:power-plug
- entity: sensor.ups1500_battery_voltage
icon: mdi:battery-charging-high
style: |
ha-card {
Is it your card or taken from somewhere?
Yes,
I took from 1st post on this thread, with my entities
Marco
First entity is duplicated, fix this first and remove the first entity from both variables and entities sections at the top of the code. If still not showing it means one or more of the entities you have at the top does not exist, you can remove them 1 at a time if you need to then you can see what one is causing the error…
replaced 1st entity and removed one by one, but still not work. All entities exist, and work, they are used in another UPS card I have
variables:
- states[''input_text.termostato_stato''].state
entities:
- input_text.termostato_stato
card:
type: entities
style: |
.card-header {
entities:
- type: section
style: |
.label {
cards:
cards:
- type: picture
style: |
ha-card {
show_icon: true
show_state: true
styles:
grid: null
card:
icon:
- height: 40px
- width: 40px
state:
- font-size: 14px
name:
cards:
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
bar-card-name {
margin-left: -10px;
entity_row: true
show_icon: true
align: split
columns: 1
max: 100
positions:
icon: inside
indicator: inside
value: inside
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
style: |
ha-card {
bar-card-name {
margin-left: -10px;
entity_row: true
- type: entities
entities:
style: |
ha-card {
I see the problem now, variables should be like this:
variables:
- states['input_text.termostato_stato'].state
- states['sensor.ups1500_status'].state
- states['sensor.ups1500_battery_level'].state
- states['sensor.ups1500_load'].state
- states['sensor.ups1500_line_voltage'].state
- states['sensor.ups1500_battery_voltage'].state
You are making a big mistake using this code. Care to read a bit more than the 1st post. And suggest to read docs for config-template-card - you will see that it is not needed to use it where it is NOT needed to use it.
Optimised code!
For those using this card already or for those that want to implement this card I have changed the code to something newer which hopefully is better (I am open to more suggestions). The card will look the same as before. I have made all entities that you need to change in capital letters to make it easier.
type: entities
card_mod:
style: |
div#states.card-content {
padding: 0px 16px 16px 16px !important;
entities:
card_type: markdown
content: |
APC --- {{states('sensor.UPS_MODEL')}} --- {{states('sensor.UPS_STATUS')}}
card_mod:
style: |
ha-card.type-markdown {
display: flex !important;
justify-content: center !important;
ha-card {
border-width: 0px !important;
ha-markdown {
padding: 16px 16px 0px !important;
cards:
- type: custom:layout-card
layout_type: custom:grid-layout
layout:
grid-template-columns: 50% 50%
place-items: center
cards:
- type: picture
image: /local/images/UPS_IMAGE.png
card_mod:
style: |
ha-card {
entity: sensor.BATTERY_REMAINING_TIME
show_icon: true
show_state: true
card_mod:
style: |
ha-card {
place-self: flex-start !important;
div#name.ellipsis {
div#state.ellipsis {
columns: 2
entity_row: true
positions:
icon: inside
indicator: 'off'
value: inside
entities:
- entity: sensor.BATTERY_REMAINING_PERCENTAGE
severity:
to: 17
color: '#d70000'
to: 34
color: '#d45e00'
to: 51
color: '#cf9000'
to: 68
color: '#cfd300'
to: 84
color: '#84cf00'
to: 100
color: '#30d000'
- entity: sensor.UPS_LOAD
icon: mdi:gauge
severity:
- value: 50
color: '#3498db'
- value: 75
color: '#f39c12'
- value: 100
color: '#e45e65'
card_mod:
style: |
ha-card {
--paper-item-icon-color: var(--primary-text-color);
card_type: entities
entities:
- entity: sensor.UPS_INPUT_VOLTAGE
- entity: sensor.UPS_BATTERY_VOLTAGE
card_mod:
style: |
ha-card {
I have made a post with hopefully better code, I hope you can check it and make any suggestions
If you got rid of CTC and using a markdown - this is better.
Thanks it works.
1st post have wrong code
Marco
I have seen from reading this top to bottom and there is quite few constructive criticisims. I like the card front end and I got 3 UPS setup with NUT communicating via UPS and tied into the same integration in HA.
My ask is what card would work best as there has been a lot of back and forth. I would just like to see the “polished or finished look” for CyberPower NAS’s. thanks
Then you will probably need 3 same cards with diff. inputs, right?
I have separate instances for each NUT via the integration. Sensors name vary a bit, but it works. NUT seems to do the heavy lifting for me. Each ups lives in a different spot in HA on Dashboard, but yes. I figured for starters lets get one that is working correctly. Then worry about the other 2.
Actually I might need 5 when its all said and done. I got 2 other UPS’s that run as part of a package. If your curious — Home Assistant sensors and CyberPower UPS via RMCARD205 – Peter Kieser
If you need 5 similar cards with diff inputs - consider using a decluttering-card.
As for “which card to declutter” - there are some cards presented here, test them one by one.
It is up to you / your education which way to choose - either “give me a working solution” or “I will test variants by myself & choose”.
