remove platform: uptime
from your sensor.
You’ve inserted it twice.
from your sensor.
Hi!
Same problem after last update.
- platform: uptime
scan_interval: 60
sensors:
uptime_ha:
friendly_name: 'Uptime Home Assistant'
icon_template: mdi:home-assistant
value_template: >-
{% set up_time = as_timestamp(now()) - as_timestamp(states('sensor.uptime')) %}
{% if up_time == 0 %}
Только запущен...
{% set minutes = (up_time // 60) | int %}
{% set hours = (minutes // 60) %}
{% set days = (hours // 24) %}
{% set weeks = (days // 7) %}
{% set minutes = (minutes % 60) %}
{% set hours = (hours % 24) %}
{% set days = (days % 7) %}
{% macro phrase(value, name) %}
{%- set value = value %}
{%- set end = 's' if value > 1 else '' %}
{{- '{} {}{}'.format(value, name, end) if value | int > 0 else '' }}
{%- endmacro %}
{% set text = [ phrase(недель, 'неделю'), phrase(дней, 'день'), phrase(часов, 'ч.'), phrase(минут, 'мин') ] | select('!=','') | list | join(', ') %}
{% set last_comma = text.rfind(',') %}
{% if last_comma != -1 %}
{% set text = text[:last_comma] + ' и' + text[last_comma + 1:] %}
{{ text }}
In template it is work
before that there was another template, it also stopped working, started looking for others, but all to no avail.
Don’t think you need scan_interval
as it only updates on start
Also, you have translated the variables in the set text line:
Should be:
{% set text = [ phrase(weeks, 'неделю'), phrase(days, 'день'), phrase(hours, 'ч.'), phrase(minutes, 'мин') ] | select('!=','') | list | join(', ') %}
Super, it`s work! Sencs.
Since Home Assistant 2020.12.0, to know the minutes since HA started (to avoid automations run at startup) a fix for uptime:
- platform: uptime
name: 'HA uptime moment'
sensors:
ha_uptime:
friendly_name: 'HA uptime minutes'
value_template: >
{{ (as_timestamp(now()) - as_timestamp(states('sensor.ha_uptime_moment'))) / 60 }}
Then in automations, use
- condition: numeric_state
entity_id: sensor.ha_uptime
above: 10
For minutes I think that should be
value_template: >
Yes. 3600 is for hours
finally how can I get the data templated? can someone paste the sensor code?
thanks
Can you psot what your sensor configuration looks like. I am a complete puttz when it comes to coding but I am trying to understand. I appreciate your assistance very much.
Thankyou
Below is the contents of my uptime_sensor.yaml. It’s included in the configuration.yaml.
- platform: uptime
sensors:
ha_uptime:
friendly_name: "Home Assistant uptime"
value_template: >-
Just restarted...
{%- endmacro %}
{% set text = [ phrase(weeks, 'week'), phrase(days, 'day'), phrase(hours, 'hr'), phrase(minutes, 'min') ] | select('!=','') | list | join(', ') %}
{% set text = text[:last_comma] + ' and' + text[last_comma + 1:] %}
{{ text }}
if you’re interested here is a streamlined version of that. Makes it easy to add or remove any unwanted values:
Great work to get the uptime working again but as for the Automations this code is difficult to work with, at least for me. I need numeric states or at least integers but this is a string attribute.
This is what I’ve concluded works for me wanting to measure the uptime in minutes and evaluate a numeric state on the same:
#HASS uptime
- platform: uptime
sensors:
uptimev2:
friendly_name: Uptimev2
value_template: >
{{ (as_timestamp(now()) - as_timestamp(states('sensor.uptime'))) // 60|int }}
And then I evaluate the uptime based on the uptimev2 numeric state, for example between 2 and 3 minutes:
I need to ask …
This code works for you? In my case the sensor is not available du to an error of the calculation.
When I put this {{ (as_timestamp(now()) - as_timestamp(states(‘sensor.uptime’))) // 60|int }} to the dev tools I get the following error:
TypeError: unsupported operand type(s) for -: ‘float’ and ‘NoneType’
Yes, it works. I had a look in my config file and I’ve apparently added another type of entity as well:
#HASS uptime
- platform: uptime
sensors:
uptimev2:
value_template: >
sensors:
home_assistant_uptime:
friendly_name: Home Assistant Uptime
value_template: >-
{% set up_time = as_timestamp(now())-as_timestamp(states('sensor.uptime')) %}
{% set minutes = (up_time // 60)|int %}
{% set hours = minutes // 60 %}
{% set days = hours // 24 %}
{% set minutes = minutes % 60 %}
{% set hours = hours % 24 %}
{% set days = days % 7 %}
{% macro phrase(value,name) %}
{{- '{} {}{}'.format(value,name,end) if value|int > 0 else '' }}
{%- endmacro %}
{% set text = [phrase(days,'day'),phrase(hours,'hour'),
phrase(minutes,'min')]
|select('!=','')|list|join(', ') %}
{{text}}
Seems there are others with similiar errors and recommended checking the template editor for debugging but maybe that is what you’ve already tried?:
Yep. Other errors …
It was just a typo. What about AI?
Hi, I have a question:
Is this still the correct way to get the uptime sensor?
- platform: uptime
Or should it follow the new template format?
template:
- sensor:
- name: "Server uptime"
state: ???
Thank you.
Yes, but isn’t it a template sensor? I feel that code follows the legacy sensor configuration format
no, where did you get the idea this is a template sensor? some of the others above are, but this is a core integration
