Im struggling with uptime kuma addon. I installed addon from official repo. Started and addon runs.
The problem is somehow related to ssl. I can’t open web ui while using ssl. I tried to open web ui using nabu casa remote access but I only get
ERR_CONNECTION_TIMED_OUT
I have ssl cert generated by dynu dns addon ( it’s a copy of let’s encrypt addon). I’m running nginx ssl proxy. I tried various thing to open uptime kuma web ui while logged with ssl on, but nothing seems to work.
I tried two server blocks, one with subdomain - no luck, one server block listening to 443 and 3001 - no luck.
I created another domain with uptimekuma.anotherdomain.com and I was able to connect to the dashboad using https://uptimekuma.anotherdomain.com but this is a partial solution while I still can’t access web ui using my ssl cert.
When I click on web ui I get
https://mydomain.com:3001 with message
ERR_SSL_PROTOCOL_ERROR
Tried different browsers, the same thing.
Is anyone running uptime kuma over ssl cert?
I’m having this issue. No idea how to get it working.
Did you manage to get it fixed?
No, I didn’t. It seems that the problem is somewhere in uptime kuma and ha developers will have to make changes in uptime kuma addon to make it work with ssl.
Maybe I misunderstood some thing but as I understood this is the case.
I don’t know anyone who managed to make uptime kuma work with ssl and nabu casa cloud.
Ah that’s a shame. It’s not end of the world. But it would be nice.
I moved my installation from debian supervised to docker-compose installation. I moved everything to docker containers and now I can use ssl on uptime kuma. Yeah, you have to learn some basic things about docker, but it’s way much easier to install and manage everything in docker containers.
Now I have four subdomain with ssl certs, for home assistant, duplicati backup, syncthing and uptime kuma.
With supervised I had problem with high cpu and memory usage. Using standalone installation it’s easy to limit container cpu and memory usage and I don’t have this problem any more. High memory usage killed my server twice and than I decided to move everything to docker compose.
