Have there been any updates on this bug? I still fail to connect to my UpTime Kuma instance.
You need to add âhttp://â or âhttps://â to the URL. Itâs not intuitive because âhostâ implies hostname, which does not have âhttp://â.
Looks like you can disable auth and It will work, Unexpected error, first installation ¡ Issue #55 ¡ meichthys/uptime_kuma ¡ GitHub
how to set up database monitoring MariaDB?
mysql://username:password@host:port/database
mysql://user:******@10.0.1.111:3307/homeassistant
does not work
Thanks for the tip! Had me stumped for a bit, then I realized canât use it with 2FA, so I then found you can use api keys and then use your username and the api key to add it to HA.
Would you care to share your yaml for that?
Cheers, Richard
I use the Uptime Kuma HACS integration to get the Uptime Kuma sensors into HA - they appear as regular sensors with an up, paused or down status that you can react to.
To monitor the Z2M network for devices, you add an MQTT monitor to Uptime Kuma. You put in your MQTT hostname, port, username and password and then for the topic I use zigbee2mqtt/DEVICENAME/availability
(where DEVICENAME is the Z2M device name), and put âonlineâ in the MQTT Success Message.
Uptime Kuma will then report the monitor as down if the Z2M device changes to anything other than online.
From there, you can do what you want in HA using the sensor, which will be called sensor.uptimekuma_MONITORNAME.
Thanks. In my case, I also needed in Z2M to turn on Settings > Availability.
I had the custom Uptime Kuma integration from HACS running and from one day to another it stopped. I reinstalled it and when I enter my uptime Kuma credentials (ip, port, user etc.) it says âFailed to connectâ I set correctly to ignore SSL and added http:// in front of the IP (as before). Uptime Kuma is running and I can access it via the IP
Any Idea what is wrong or on which door I should knock?
2024.5 broke uptime kuma, frigate and adguard integrations using ssl. It also broke tuya local. 2024.5.1 didnt fixed the issue.
it already broke before I updated to 2024.5
