I was wondering if someone could write some good integration for Uptime Robot into HA using the latest API:
Pretty sure this should be moved to Feature Requests.
Interested in this as well. As a workaround I use IMAP Email Content: https://home-assistant.io/components/sensor.imap_email_content/
+1 for this feature
@Bart274, @johmei, @gr4z
Do you have an idea of what you want this to do?
I’m thinking one sensor entity pr monitor, with an online/offline state.
Other ideas?
That is a limit in the uptimerobot API, they have set it to be max 50
Thanks, I actually found that after posting.
limit - optional (used for pagination. Defines the max number of records to return for the response. Default and max. is 50)
