Uptime sensor in hours or days?
That would do it. :grinning: I’m glad you figured it out.
One more snippet for the crowd:
  - platform: uptime
    lambda: |-
      return (id(uptime_sec).state/60)/60/24;
    icon: mdi:clock-start
    unit_of_measurement: days
I wanted to have the uptime still in seconds and have another one breaking it down in days
And…here is another version to show a more human readable uptime in days, hours, minutes, seconds:
  - platform: uptime
text_sensor:
    lambda: |-
      int seconds = (id(uptime_sec).state);
      int days = seconds / (24 * 3600);
      seconds = seconds % (24 * 3600);
      int hours = seconds / 3600;
      seconds = seconds % 3600;
      int minutes = seconds /  60;
      seconds = seconds % 60;
      return { (String(days) +"d " + String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
    update_interval: 113s
Result:
uptime
Great stuff guys! Here’s a version I did that only shows variables if they are positive. (i.e. doesn’t state ā€œdaysā€ until it has been up for at least 1 day.)
  - platform: uptime
text_sensor:
    name: ${friendly_name} - Uptime
    update_interval: 42s
    lambda: |-
      int seconds = (id(uptime_seconds).state);
      if ( days ) {
      } else if ( hours ) {
        return { (String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
      } else if ( minutes ) {
        return { (String(minutes) +"m "+ String(seconds) +"s").c_str() };
      } else {
        return { (String(seconds) +"s").c_str() };
-J
This works like a charm, thanks!
Guys, I’m really liking the human readable uptime strings but have you noticed that just after you program the thing it gives a value that is MASSIVE? For example:
Thanks for sharing this @JayElDubya, I used it and added the ā€œStarting upā€ to take care of the huge negative number right after flashing.
    lambda: |-
      int seconds = (id(${node_name}_uptime_raw).state);
      if ( days > 3650 ) {
        return { "Starting up" };
      } else if ( days ) {
      } else {
I also determined that the huge negative number was causing a boot loop on the ESP32 so now I have used this code to reflash all my ESPHome devices so they come up with more readable and accurate values. :slight_smile:
nice find. Will update my nodes.I have had random reboots on several devices that eventually sort themselves out. I wonder if there’s some variation as to what order things are initialized upon boot. Hopefully this stops the overflow. For what it’s worth, I’ve noticed high values on HA sensor values as well before it actually connects to HA and refreshes the value. Is there a way, maybe with a clever filter, to have an initial value (like 0) for a sensor to have before the data comes in?
-Josh
I’m not super found of limits (although I highly doubt my nodes will reach close to 10 years uptime).
This works even better:
text_sensor:
  - platform: uptime
    name: "${friendly_name} Uptime Sensor"
    update_interval: 60s
    on_raw_value:
      then:
        - logger.log:
            format: "Raw Value of Uptime sensor: %f"
            args: ['id(${node_name}_uptime_raw).raw_state']
            level: INFO
        - text_sensor.template.publish:
            state: !lambda |-
              int seconds = round(id(${node_name}_uptime_raw).raw_state);
              if ( days ) {
              } else {
Edit: I’ve added this as an example to the esphome doc: https://esphome.io/components/sensor/uptime.html#human-readable-sensor
Is this good according to the new template style too? Working fine on my end, but still want to check.
Hm, that was 3 years ago, and I have completely changed my approach. That code is probably still going to work fine - I haven’t heard about deprecating the old template format.
What I am doing nowadays is to have a time entity on the ESP device, then have a text_sensor that exposes that value, and then set the device class to timestamp inside Home Assistant. The major advantage of this approach is that the entity only updates once (as opposed to every 60 seconds) and thus reduces the load on the database, and it uses the built-in way to display a human-readable uptime like ā€œ2 days agoā€ or ā€œLast monthā€.
text_sensor:
    name: "${display_devicename} Last Restart Time"
    icon: mdi:clock
    entity_category: diagnostic
#    device_class: timestamp
time:
  - platform: homeassistant
    on_time_sync:
      then:
        # Update last restart time, but only once.
        - if:
            condition:
              lambda: 'return id(last_restart_time).state == "";'
            then:
                  state: !lambda 'return id(homeassistant_time).utcnow().strftime("%Y-%m-%dT%H:%M:%S.000000+00:00");'
I’m using this code (original code from Frenck):
time:
    on_time_sync:
      - component.update: uptime_timestamp
  - platform: uptime
    accuracy_decimals: 0
    update_interval: never
    lambda: |-
      static float timestamp = (
        id(current_time).utcnow().timestamp - id(uptime_sec).state
      return timestamp;
I use the same, but I’ve set the first sensor to internal only, so it won’t end up in HA.
It’s internal by default if it has no name:
ah, didn’t know that, thanks :slight_smile:
modified it to comply with new guidelines
template:
  - sensor:
      - name: "Huawei Modem uptime"
        state: >
          {% set uptime = states.sensor.huawei_igd_uptime.state | int %}
          {% set days = (uptime / 86400) | int %}
          {%- if days > 0 -%}
            {{ days }} days, {{ (uptime - (days * 86400)) | int | timestamp_custom('%H:%M:%S', false) }}
          {%- else -%}
            {{ uptime | int | timestamp_custom('%H:%M:%S', false) }}
          {%- endif -%}
Edit: removed unit, bcz it is self explanatory.
device_class: duration
can be used but what difference it makes is still not known in uptime.
Great! it works.
It gives warning in compilation but it works. thank!
Hi guys,
why not using copy integration as suggested for wifi signal component to show rssi data in percentage?
Seems to be the new guideline, am I wrong?
This code ends up sending the device_last_restart to HA every 60 seconds, even if update_internval = 6h or a filter for delta 0.01 is added… it keeps sending the same last restart data every minute.
