In some cases it can help avoid false positives when triggering binary_sensor on entity state ‘unavailable’.
sensor.uptime already helps to suppress triggers after HA Core reboot.
As well - add-on restart also push entities in ‘unavailable’ state.
What the heck is “triggering smth”?
Is this a feature request?
If so, I suggest you more clearly articulate your request in the appropriate category.
It is ‘something’. Probably not widely used shortening.
Missed to set category, thanks for advice.
Ok I think I’m following now. Thank you. You want uptime sensors for addons so you can use them in conditions to prevent false triggering during updates or restarts of addons.
Nit picking, this is a bit of a misnomer:
You reboot the Host machine. Which affects addons, and everything else.
You restart the core server. Which does not affect addons.
Don’t forget to vote for your own request.
Exactly. Thank You very much.
