Any ideas what might be causing these error messages in the log files on startup?
core-ssh:/config# hassio su logs
Error decoding json invalid character '\x1b' looking for beginning of value: 18-10-20 14:55:26 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
Error decoding json invalid character '-' after top-level value: 2018-10-20 11:37:08 INFO (MainThread) [homeassistant.components.automation] Initialized trigger House Mode-Morning
- Appears only using the cli .
- These errors appear BEFORE the first entry into the log file. (curious)
Something https://github.com/urfave/cli is choking on?
Could be an error in the logfile init process?
(My docker-fu is not strong enough to peek at the internal log files)
