Hello All ,
Before I ask , I would like to mention I did really gone though the community posts for the solution.
What I have done:
I followed the guide to setup duckdns and configuration on HA. His video has been recommended on HA startup page.
Issue I am facing:
After following the guide, I am unable to access HA from https://XXXXX.duckdns.org
Steps I have followed and configurations:
As mentioned I have followed the mentioned guide and set up as-is.
duckdns - addon configuration -
lets_encrypt:
accept_terms: true
certfile: fullchain.pem
keyfile: privkey.pem
token: XXXXXX
domains:
- XXXX.duckdns.org
aliases: []
seconds: 300
configuration.yaml
#uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: xxx.duckdns.org
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
ip_ban_enabled: True
login_attempts_threshold: 3
port forwarding from my router. This is centurylink.
as this isn’t showing completely, here is the setup page before clicking submit. And I have tried alerting the ports as well.
expectation is when I hit the URL https://xxx.duckdns.org I should get the HA’s login page. I have been getting as
Also, I am unable to use local IP as well
This site can’t be reached
I have even followed this excellent community reply of someone who faced similar issue, but no luck.
Some of other checks I did:
my modem isn’t cg-nat enabled - I have confirmed by finding the IP coming from here and on my modem login page the IP it is showing. This shows that the WAN IP-address is OK and thee ISP isn’t using CGN. – please confirm if my understanding is wrong.
I have verified whether 443 port is exposed or not on https://canyouseeme.org/
Success: I can see your service on xxx.xxx.xx.xxx on port (443)
Your ISP is not blocking port 443
by removing the config from configurations.yaml(luckily I have ssh setup already done) the site is back online and available to under locally. Which confirmed me clearly some issue with port forwarding or duckdns config/setup.
one thing I wanna mention, is I am new to HA and just setup HA on pi4. But I am using non stable version. If that need to be considered.
~ $ ha os info
board: rpi4-64
boot: A
version: "5.3"
version_latest: "4.15"
Thank you for reading this, if you can help me here would be really great.
