@JorgeMaTeixeira yes, this is a known interference!
Unfortunately USB 3.0 signals can interfere with radio transmissions in the 2.4 GHz band. This may affect Bluetooth, Wifi and Zigbee communication.
What you can try to do is using better cables for USB 3.0 and/or try to move any communicating adaptors (like Zigbee sticks) as far away as possible from the Pi and its USB 3 ports using a USB male/female cable. I would also connect such sticks to the USB 2 ports to limit interference of the stick with the signal on its own cable (although the 3.0 ports should switch back to USB 2 protocol on such sticks).
I finally found that the long boot times in my setup were a result of the JMicron JMS583 bridge chip in my SATA adapter. After updating the adapter firmware booting times on USB 3.0 are down to 3 minutes. Read the full story here:
Pi can boot from USB, I have flashed Rapsbian on USB Pendrive 16GB and it boots from it. It does not on with my SSDā¦ So It seems that itās SSD issue, or HassOS. I need to try with bigger USB Pendrive, maybe HassOS will boot from 64GB Pendrive
For what itās worth, @Jpsy his SSD boots with EEPROM firmware 2020-09-03, mine doesnāt.
Mine boots with v2020.07.16-138a1. For me it was worth the try.
Using the manual on this https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=245931 page it was possible to achieve fast loading. In cmdline.txt added usb-storage.quirks=xxxx:yyyy:u, where xxxx and yyyy are the values of idVendor and idProduct, respectively
Good afternoon ,
I am trying to move from an rpi3 running HA via usb stick to a new rpi4b 4gb , i bought a new usb stick , which i tried with kodi and boot without issues , on HA when i power up the rpi give me this msg
Thanks Vlad
i reboot via ssh , had kodi on with an ip , shall i just flag wait network before boot ?
Or is there any other setting to be applied ?
If i boot via raspbian i navigate.
