Hi all,
I’m looking for a contraption that will allow me to power a usb-c presence sensor like in the picture below. What should I be searching for? What would such an adapter be called?
Thank you in advance
Hi all,
Something like this.
But keep in mind this will need some kind of isolation to not make the light fixture connected to mains.
And then a usb c break out board or something
IF you’re technically and electronically* inclined, you can get all the components you need by opening up a USB-C phone charger and hooking up the internals to the Live & Neutrals at your ceiling rose.
* DANGER OF ELECTROCUTION
If your device connects to mains electricity (AC power) there is danger of electrocution if not installed properly. If you don’t know how to install it, please call an electrician.
Remember: SAFETY FIRST. It is not worth the risk to yourself, your family and your home if you don’t know exactly what you are doing. Never tinker or try to flash a device using the serial programming interface while it is connected to MAINS ELECTRICITY (AC power).
Instead of tampering with the electrical wiring you could look up a bulb like this for the socket that you have available to you:
https://www.amazon.com.au/USB-Light-Bulb-LampCharger-Combo/dp/B01MZJ0UO4
