I do not know how I can add Sonoff ZB MINI device to my home assistant. I have integration with CC2531 through “Zigbee Home Automation”, I am not using ZigBee2MQTT. It does not find the device. In the logs I see:
It didn’t help. The green LED flashes all the time, I hold the reset button 5-10s, the LED flashes all the time. When I press the switch briefly, it works and the CC2531 captures the signals. But adding is not working. I have 8 devices on the coordinator.
What firmware version is on your CC2531. There is a known bug in all but the latest firmware versions for the CC2531 that they fail to pair after a while. Unplugging the CC2531 and re-plugging solves it, but upgrading to the latest firmware is better.
