USB mapping issue after rebooting
I keep having a problem with my 3 USB Zigbee dongles. After the restart, they are assigned differently. Is it possible to set the assignment USB0,1,2,3 in the system?
Use the serial by-id to define them in the ZigBee integration instead of the usb path.
Also, why do you have 3 different ZigBee dongles plugged in?
ttyUSB0
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_7093f57f7e93eb11ac8d214f3d98b6d1-if00-port0
ttyUSB1
/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_9296da142b27ee11be108bc1f49e3369-if00-port0
ttyUSB2
/dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
Ok, so in the configuration for the ZigBee integration(s) you’re using, you need to change from eg. ‘ttyUSB0’ to ‘/dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_7093f57f7e93eb11ac8d214f3d98b6d1-if00-port0’
I’m going to ask you again. Why do you have 3 ZigBee dongles plugged in?
Are you running multiple ZigBee integrations?
Yes,
multiple ZigBee integrations.
It doesn’t work that way.
After rebooting, the configuration has changed.
ttyUSB0
ttyUSB1
ttyUSB2
If you set up your devices to be addressed by /dev/serial/by-id it won’t matter if a device one day is ttyUSB0 and the next day ttyUSB1.
So in your case you change ttyUSB0 to /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
Okay, understood, thanks.
Works so far.
