USB mysensors gateway problem
Sorry for my English. I have a problem with adding switches to home assistant mysensors [ )
// Enable debug prints to serial monitor
//#define MY_DEBUG
#define MY_GATEWAY_SERIAL
#include <MySensors.h>
#include <Bounce2.h>
//#include “PCF8574.h”
//#include “Adafruit_MCP23017.h”
#if defined(PCF8574_H) || defined(Adafruit_MCP23017_H)
#define USE_EXPANDER
#include <Wire.h> // Required for I2C communication
uint8_t expanderAddresses[] = {0x20};
const int numberOfExpanders = sizeof(expanderAddresses);
PCF8574 expander[numberOfExpanders];
#elif defined(Adafruit_MCP23017_H)
Adafruit_MCP23017 expander[numberOfExpanders];
#endif
#define E(expanderNo, ExpanderPin) (((expanderNo+1)<<8) | (ExpanderPin))
#endif
// No Button Constant
#define NOB -1
#define MULTI_RELAY_VERSION 9
#define RELAY_STATE_STORAGE 1
const uint8_t RELAY_TRIGGER_LOW = 0;
const uint8_t RELAY_TRIGGER_HIGH = 1;
const uint8_t RELAY_STARTUP_ON = 2;
const uint8_t RELAY_STARTUP_OFF = 4;
const uint8_t RELAY_STARTUP_MASK = RELAY_STARTUP_ON | RELAY_STARTUP_OFF;
enum ButtonType {
MONO_STABLE = 0,
BI_STABLE = 1,
DING_DONG = 2 // HIGH state immediatly after push, LOW state after release
typedef struct {
int sensorId;
int relay;
int button;
uint8_t relayOptions;
ButtonType buttonType;
const char * relayDescription;
} RelayButton;
// CONFIGURE ONLY THIS ARRAY!
// Row params: sensor ID - sensor ID reported on MySensor Gateway
// relay pin - Expander supported
// button pin - <0 for virtual buttons (only available in MySensor Gateway); no support for Expander
// relay options - [RELAY_TRIGGER_LOW|RELAY_TRIGGER_HIGH] {RELAY_STARTUP_ON|RELAY_STARTUP_OFF}
// button type - [MONO_STABLE|BI_STABLE|DING_DONG]
// relay description - reported on MySensor Gateway, can help identify device on initial configuration in Home Automation App, can be empty ("")
RelayButton myRelayButtons[] = {
//WŁĄCZNIKI ŚWIATŁA
{1, 2, A0, RELAY_TRIGGER_HIGH, MONO_STABLE, “ŚWIATŁO PRZED DOMEM_1”}, //
{2, 3, A1, RELAY_TRIGGER_HIGH, MONO_STABLE, “ŚWIATŁO PRZED GARAŻEM”}, //
{3, 4, A2, RELAY_TRIGGER_HIGH, MONO_STABLE, “ŚWIATŁO PRZEDSIONEK”}, //
{4, 5, A3, RELAY_TRIGGER_HIGH, MONO_STABLE, “ŚWIATŁO KORYTARZ”}, //
{5, 6, A4, RELAY_TRIGGER_HIGH, MONO_STABLE, “ŚWIATŁO KORYTARZ LED”}, //
{6, 7, A5, RELAY_TRIGGER_HIGH, MONO_STABLE, “ŚWIATŁO POKÓJ 1”}, //
{7, 8, A6, RELAY_TRIGGER_HIGH, MONO_STABLE, “ŚWIATŁO POKÓJ 2”}, //
{8, 9, A7, RELAY_TRIGGER_HIGH, MONO_STABLE, “ŚWIATŁO SALON”}, //
{9, 10, A8, RELAY_TRIGGER_HIGH, MONO_STABLE, “ŚWIATŁO JADALNIA”}, //
{10, 11, A9, RELAY_TRIGGER_HIGH, MONO_STABLE, “ŚWIATŁO KUCHNIA”}, //
{11, 12, A10, RELAY_TRIGGER_HIGH, MONO_STABLE, “ŚWIATŁO KUCHNIA LED”}, //
{12, 14, A11, RELAY_TRIGGER_HIGH, MONO_STABLE, “ŚWIATŁO TARAS”}, //
{13, 15, A12, RELAY_TRIGGER_HIGH, MONO_STABLE, “ŚWIATKŁO SYPIALNIA”}, //
TARAS"}, //
{14, 16, A12, RELAY_TRIGGER_HIGH, MONO_STABLE, “SALON LISTWA LED”}, //
//CZUJNIK RUCH
{15, 101, 53, RELAY_TRIGGER_HIGH, MONO_STABLE, “CZUJNIK TARAS”}, //
{16, 102, 52, RELAY_TRIGGER_HIGH, MONO_STABLE, “CZUJKA PRZED DOMEM_1”}, //
{17, 103, 51, RELAY_TRIGGER_HIGH, MONO_STABLE, “CZUJKA PRZED GARAŻEM”}, //
{18, 104, 50, RELAY_TRIGGER_HIGH, MONO_STABLE, “CZUJNIK PRZEDSIONEK”}, //
{19, 105, 49, RELAY_TRIGGER_HIGH, MONO_STABLE, “CZUJNIK 1 KORYTARZ”}, //
{20, 106, 48, RELAY_TRIGGER_HIGH, MONO_STABLE, “CZUJNIK 2 KORYTARZ”},//
{21, 107, 47, RELAY_TRIGGER_HIGH, MONO_STABLE, “CZUJNIK KUCHNIA LED”}, //
{22, 108, 46, RELAY_TRIGGER_HIGH, MONO_STABLE, “OGRZEWANIE GARAŻ”}, //
//OGRZEWANIE
{23, 109, 45, RELAY_TRIGGER_HIGH, MONO_STABLE, “OGRZEWANIE POKÓJ_1”}, //
{24, 1010, 44, RELAY_TRIGGER_HIGH, MONO_STABLE, “OGRZEWANIE POKÓJ_2”}, //
{25, 1011, 43, RELAY_TRIGGER_HIGH, MONO_STABLE, “OGRZEWANIE SYPIALNIA”}, //
{26, 1012, 42, RELAY_TRIGGER_HIGH, MONO_STABLE, “OGRZEWANIE SALON”}, //
//GNIAZDKA
{27, 1012, 41, RELAY_TRIGGER_HIGH, MONO_STABLE, “GNIAZDKO SALON1”}, //
{28, 1013, 40, RELAY_TRIGGER_HIGH, MONO_STABLE, “GNIAZDKO SALON2”}, //
{29, 1014, 39, RELAY_TRIGGER_HIGH, MONO_STABLE, “GNIAZDKO TARAZ POMPA WODY”}, //
{30, 1015, 39, RELAY_TRIGGER_HIGH, MONO_STABLE, “GNIAZDKO SYPIALNIA”}, //
//{21, 29, 48, RELAY_TRIGGER_LOW, BI_STABLE, “Gabinet”}, // WŁ: Gabinet
//{22, 9, 47, RELAY_TRIGGER_LOW, BI_STABLE, “Hall 2”}, // WŁ: Hall II/Schody prawy
//{19, 8, 46, RELAY_TRIGGER_LOW, BI_STABLE, “Klatka Schodowa”}, // WŁ: Hall II/Schody lewy
//{24, 11, 45, RELAY_TRIGGER_LOW, BI_STABLE, “Garderoba”}, // WŁ: Garderoba
//{26, 7, 43, RELAY_TRIGGER_LOW, BI_STABLE, “Pok. nad kuchnią 1”}, // WŁ: Pok. nad kuchnią 1
//{27, 10, 42, RELAY_TRIGGER_LOW, BI_STABLE, “Pok. nad salonem 2”}, // WŁ: Pok. nad salonem 2
//{29, 5, 40, RELAY_TRIGGER_LOW, BI_STABLE, “Ł2”}, // WŁ: Hall II/Ł2 lewy
//{30, 6, 39, RELAY_TRIGGER_LOW, BI_STABLE, “Ł2 - Taśma LED”}, // WŁ: Hall II/Ł2 prawy
//{22, 9, 38, RELAY_TRIGGER_LOW, BI_STABLE, “Hall 2”}, // WŁ: Hall II/Sypialnia
//{32, 12, 37, RELAY_TRIGGER_LOW, BI_STABLE, “Sypialnia 2”}, // WŁ: Sypialnia 2
//{34, 28, -1, RELAY_TRIGGER_LOW | RELAY_STARTUP_ON, MONO_STABLE, “Halogen - Garaż”}, // WŁ: Virtual Button 1
//{35, 30, -2, RELAY_TRIGGER_LOW | RELAY_STARTUP_OFF, MONO_STABLE, “Ł1 - Wentylator”}, // WŁ: Virtual Button 2
//{36, 15, -3, RELAY_TRIGGER_LOW | RELAY_STARTUP_OFF, MONO_STABLE, “Halogen - wschód”}, // WŁ: Virtual Button 3
//{40, 2, -7, RELAY_TRIGGER_LOW | RELAY_STARTUP_OFF, MONO_STABLE, “Ł2 - wentylator”}, // WŁ: Virtual Button 7
const int numberOfRelayButtons = sizeof(myRelayButtons) / sizeof(RelayButton);
typedef struct {
int firstButton;
int nextButton;
} RelayMultiButtons;
RelayMultiButtons relayMultiButtons[numberOfRelayButtons];
uint8_t myRelayState[numberOfRelayButtons];
// MySensors - Sending Data
// To send data you have to create a MyMessage container to hold the information.
MyMessage msgs[numberOfRelayButtons];
Bounce myButtonDebouncer[numberOfRelayButtons];
//Function Declaration
uint8_t loadRelayState(int relayNum, uint8_t forceEeprom = 0);
void saveRelayState(int relayNum, uint8_t state, uint8_t useEeprom);
void saveRelayState(int relayNum, uint8_t state);
void changeRelayState(int relayNum, uint8_t relayState);
// MySensors - This will execute before MySensors starts up
void before() {
Serial.begin(115200);
#ifdef USE_EXPANDER
/* Start I2C bus and PCF8574 instance */
for(int i = 0; i < numberOfExpanders; i++) {
expander[i].begin(expanderAddresses[i]);
#endif
// initialize multiple buttons list structure
for (int i = 0; i < numberOfRelayButtons; i++) {
relayMultiButtons[i].firstButton = -1;
relayMultiButtons[i].nextButton = -1;
// find multiple buttons for the same relay (uni-directional list)
for (int i = 0; i < numberOfRelayButtons-1; i++) {
if (relayMultiButtons[i].firstButton == -1) {
int prevRelayButton = i;
for (int j = i+1; j < numberOfRelayButtons; j++) {
if (myRelayButtons[i].relay == myRelayButtons[j].relay) {
relayMultiButtons[prevRelayButton].firstButton = i;
relayMultiButtons[prevRelayButton].nextButton = j;
relayMultiButtons[j].firstButton = i;
prevRelayButton = j;
// if version has changed, reset state of all relays
int versionChangeResetState = (MULTI_RELAY_VERSION == loadState(0) ) ? 0 : 1;
// if this relay has multiple buttons, load only first
if (relayMultiButtons[i].firstButton == -1 || relayMultiButtons[i].firstButton == i) {
// Then set relay pins in output mode
#ifdef USE_EXPANDER
if ( myRelayButtons[i].relay & 0xff00 ) {
// EXPANDER
int expanderNo = (myRelayButtons[i].relay >> 8) - 1;
int expanderPin = myRelayButtons[i].relay & 0xff;
expander[expanderNo].pinMode(expanderPin, OUTPUT);
} else {
#endif
pinMode(myRelayButtons[i].relay, OUTPUT);
#ifdef USE_EXPANDER
#endif
  uint8_t isTurnedOn = 0;
  if (myRelayButtons[i].relayOptions & RELAY_STARTUP_ON) {
    isTurnedOn = 1;
  } else if (myRelayButtons[i].relayOptions & RELAY_STARTUP_OFF) {
  } else {
    // Set relay to last known state (using eeprom storage)
    isTurnedOn = loadRelayState(i, 1); // 1 - true, 0 - false
    if (versionChangeResetState && isTurnedOn) {
      saveRelayState(i, 0, 1);
      isTurnedOn = 0;
  changeRelayState(i, isTurnedOn);
  myRelayState[i] = isTurnedOn;
if (versionChangeResetState) {
// version has changed, so store new version in eeporom
saveState(0, MULTI_RELAY_VERSION);
// executed AFTER mysensors has been initialised
void setup() {
for(int i = 0; i < numberOfRelayButtons; i++) {
if (myRelayButtons[i].button >= 0) {
// No Expander support for buttons (de-bouncing)
pinMode(myRelayButtons[i].button, INPUT_PULLUP); // HIGH state when button is not pushed
// Setup locally attached sensors
delay(5000);
// Send state to MySensor Gateway
// if this relay has multiple buttons, send only first
msgs[i] = MyMessage(myRelayButtons[i].sensorId, V_LIGHT);
uint8_t relayState;
relayState = 1;
relayState = 0;
} else {
relayState = loadRelayState(i);
send(msgs[i].set(relayState)); // send current state
// Setup buttons
// setup debouncer
myButtonDebouncer[i] = Bounce();
myButtonDebouncer[i].attach(myRelayButtons[i].button);
myButtonDebouncer[i].interval(50);
void loop() {
if (myRelayButtons[i].button >= 0 && myButtonDebouncer[i].update()) {
int buttonState = myButtonDebouncer[i].read();
#ifdef MY_DEBUG
Serial.print("# Button “);
Serial.print(i);
Serial.print(” changed to: ");
Serial.println(buttonState);
#endif
  int relayNum = (relayMultiButtons[i].firstButton == -1) ? i : relayMultiButtons[i].firstButton;
  if (myRelayButtons[i].buttonType == DING_DONG) {
    if (buttonState == LOW) { // button pressed
      changeRelayState(relayNum, 1);
      send(msgs[relayNum].set(1));
    } else { // button released
      changeRelayState(relayNum, 0);
      send(msgs[relayNum].set(0));
  } else if (myRelayButtons[i].buttonType == BI_STABLE || buttonState == HIGH) {
    // If button type is BI_STABLE, any change will toggle relay state
    // For MONO_STABLE, button must be pushed and released (HIGH)
    uint8_t isTurnedOn = ! loadRelayState(relayNum); // 1 - true, 0 - false
    changeRelayState(relayNum, isTurnedOn);
    send(msgs[relayNum].set(isTurnedOn));
    saveRelayState(relayNum, isTurnedOn);
// MySensors - Presentation
// Your sensor must first present itself to the controller.
// The presentation is a hint to allow controller prepare for the sensor data that eventually will come.
// Executed after “before()” and before “setup()” in: _begin (MySensorsCore.cpp) > gatewayTransportInit() > presentNode()
void presentation() {
// Send the sketch version information to the gateway and Controller
sendSketchInfo(“Multi Relay”, “1.2”);
// Register every relay as separate sensor
// if this relay has multiple buttons, register only first
// Register all sensors to gw (they will be created as child devices)
// void present(uint8_t childSensorId, uint8_t sensorType, const char *description, bool ack);
// childSensorId - The unique child id you want to choose for the sensor connected to this Arduino. Range 0-254.
// sensorType - The sensor type you want to create.
// description An optional textual description of the attached sensor.
// ack - Set this to true if you want destination node to send ack back to this node. Default is not to request any ack.
present(myRelayButtons[i].sensorId, S_BINARY, myRelayButtons[i].relayDescription);
// MySensors - Handling incoming messages
// Nodes that expects incoming data, such as an actuator or repeating nodes,
// must implement the receive() - function to handle the incoming messages.
// Do not sleep a node where you expect incoming data or you will lose messages.
void receive(const MyMessage &message) {
// We only expect one type of message from controller. But we better check anyway.
if (message.type == V_STATUS) {
uint8_t isTurnedOn = message.getBool(); // 1 - true, 0 - false
int relayNum = getRelayNum(message.sensor);
if (relayNum == -1) return;
// TODO: support for DING-DONG
// Store state in eeprom if changed
if (loadRelayState(relayNum) != isTurnedOn) {
send(msgs[relayNum].set(isTurnedOn)); // support for OPTIMISTIC=FALSE (Home Asistant)
#ifdef MY_DEBUG
// Write some debug info
Serial.print("# Incoming change for sensor: " + relayNum);
Serial.println(", New status: " + isTurnedOn);
#endif
uint8_t loadRelayState(int relayNum, uint8_t forceEeprom) {
uint8_t relayState;
if (forceEeprom) {
relayState = loadState(RELAY_STATE_STORAGE + relayNum);
} else {
relayState = myRelayState[relayNum];
#ifdef MY_DEBUG
Serial.print("# loadRelayState: “);
Serial.print(relayNum);
if (forceEeprom) {
Serial.print(”(byte “);
Serial.print(RELAY_STATE_STORAGE + relayNum);
Serial.print(”)");
Serial.print(" = ");
Serial.println(relayState);
#endif
return(relayState);
void saveRelayState(int relayNum, uint8_t state, uint8_t useEeprom) {
int mainRelayNum = (relayMultiButtons[relayNum].firstButton == -1) ? relayNum : relayMultiButtons[relayNum].firstButton;
myRelayState[mainRelayNum] = state;
if (useEeprom && (relayNum == mainRelayNum)) {
saveState(RELAY_STATE_STORAGE + mainRelayNum, state);
int nextButton = mainRelayNum;
// update all buttons
while ((nextButton = relayMultiButtons[nextButton].nextButton) != -1) {
myRelayState[nextButton] = state;
void saveRelayState(int relayNum, uint8_t state) {
uint8_t useEeprom = ((myRelayButtons[relayNum].relayOptions & RELAY_STARTUP_MASK) == 0);
saveRelayState(relayNum, state, useEeprom);
void changeRelayState(int relayNum, uint8_t relayState) {
uint8_t relayTrigger = myRelayButtons[relayNum].relayOptions & RELAY_TRIGGER_HIGH;
uint8_t digitalOutState = relayState ? relayTrigger : ! relayTrigger;
#ifdef USE_EXPANDER
if ( myRelayButtons[relayNum].relay & 0xff00 ) {
int expanderNo = (myRelayButtons[relayNum].relay >> 8) - 1;
int expanderPin = myRelayButtons[relayNum].relay & 0xff;
expander[expanderNo].digitalWrite(expanderPin, digitalOutState);
} else {
#endif
digitalWrite(myRelayButtons[relayNum].relay, digitalOutState);
#ifdef USE_EXPANDER
#endif
int getRelayNum(int sensorId) {
if (myRelayButtons[i].sensorId == sensorId) return(i);
return(-1);
} else {
#endif
#ifdef USE_EXPANDER
#endif
return(-1);
gateways:
- device: ‘/dev/ttyUSB0’
persistence_file: ‘mysensors.json’
baud_rate: 115200
- device: ‘/dev/ttyACM0’
persistence_file: ‘mysensors3.json’
baud_rate: 115200
optimistic: true
persistence: true
retain: true
version: ‘2.3’
