What is the easiest way to use a USB NFC card reader (for example ACR122U) with Home Assistant?
I’m using Home Assistant Container. Ideally I would just plug one in, mount the device into the container and let a Home Assistant integration create tag events. Is that possible?
Yeah, I saw that. If the USB one isn’t possible, I’ll build an ESP8266-based one. Will probably go for Tasmota instead of ESPHome as I already use that on other equipment and I can still use USB for power. It’s just that the USB reader comes complete with a case and cable and everything and it doesn’t need Wifi… all around it seems a better choice if it will be set up right next to the Home Assistant server (Pi).
I just realized… instead of going PN532 → ESP8266 → Wifi → Home Assistant I could just hook up the PN532 to the Raspberry Pi’s GPIOs directly.
However I cannot find any information on how to get the tags into Home Assistant. All I can find is either using the Tasmota integration or the ESPHome integration. Is there a generic API (REST? MQTT?) for that?
Nope, I gave up for now. It would have been just a gimmick anyway and it turned out to be a bit annoying. I hooked up a generic PN532-based reader to a Raspberry Pi and I tried all three connection types (serial, I2C and SPI) with the software that is available in Debian/Pi OS (I think it’s called nfc-tools.) Some of the connection types are just slow, some are flaky and require frequent restarts of the tool, all of them require polling. The last point might be a limitation of the hardware, but the protocol is complicated and the implementation in nfc-tools is documented rather poorly.
This was my plan too. I was even fine buying a $200 reader, but if it’s gonna be such a pain to hook up to Home Assistant, who cares .
I saw some ideas online about using Web Hooks and MQTT to hook it up, but you’d have to first read it, and then send the command somehow requiring a 3rd party app or something you write yourself.
Hm, the tags should automatically appear under Settings > Tags, right?
It won’t, because that requires triggering the tag_scanned event, which I couldn’t figure out how to do using MQTT.
You have to write data to the tags using the Home Assistant companion app. Whatever you chose as the Tag ID when creating/writing the tag is what will show up as the state of the sensor.
If you haven’t written anything to the tag it should still show up as a generic_SOMEHEXCODE, but I haven’t tested it.
What I did was I wrote the track ID I wanted to play as the Tag ID (e.g. library://track/172) and made an automation that calls the music_assistant.play_media action with the state of the sensor as media ID (using a template).
That way, I don’t need to maintain a mapping of TagID → TrackID anywhere.
How do I link it up to Home Assistant’s tags functionality? A text sensor is quite useless, I could do that with Node-RED or a shell script even. My question is about how to hook into the tags feature, so that it works, well, like tags do.
