I’m very new to Home Assistant. I got HA working well and linked it to Homebridge (to use with Apple’s homekit). I’ve installed it on a raspberry pi zero using the All-in-one Installer, and it’s all working extremely well… until now!
Since I’ve installed it on the pi zero, I had to connect a powered usb hub to it in order to plug in a wifi dongle and now a new z-wave dongle I just got today. The model is the Z-stick gen 5.
My problem: Home Assistant isn’t finding my z-wave stick nor config route.I followed BRUH Automation’s youtube tutorial (https://www.youtube.com/watch?v=ajklDCaOGwY) to set up the z-wave stick. Here’s the log of the errors:
16-08-25 14:27:31 homeassistant.loader: Unable to find component config_path
16-08-25 14:27:31 homeassistant.loader: Unable to find component usb_path
16-08-25 14:27:37 homeassistant.bootstrap: Error during setup of component zwave
File “/srv/hass/hass_venv/lib/python3.4/site-packages/openzwave-0.3.1-py3.4.egg/openzwave/option.py”, line 72, in init
raise ZWaveException(u"Can’t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
File “/usr/lib/python3.4/traceback.py”, line 181, in format_exception
return list(_format_exception_iter(etype, value, tb, limit, chain))
File “/usr/lib/python3.4/traceback.py”, line 146, in _format_exception_iter
for value, tb in values:
File “/usr/lib/python3.4/traceback.py”, line 125, in _iter_chain
context = exc.context
AttributeError: ‘NoneType’ object has no attribute ‘context’
File “/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/bootstrap.py”, line 156, in _setup_component
result = component.setup(hass, config)
File “/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/zwave.py”, line 305, in setup
default_zwave_config_path),)
File “/srv/hass/hass_venv/lib/python3.4/site-packages/openzwave-0.3.1-py3.4.egg/openzwave/option.py”, line 75, in init
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: ‘Zwave Generic Exception : Error when retrieving device /zwaveusbstick : [‘Traceback (most recent call last):\n’, ’ File “/srv/hass/hass_venv/lib/python3.4/site-packages/openzwave-0.3.1-py3.4.egg/openzwave/option.py”, line 72, in init\n raise ZWaveException(u"Can\‘t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\n’, ’ File “/usr/lib/python3.4/traceback.py”, line 181, in format_exception\n return list(_format_exception_iter(etype, value, tb, limit, chain))\n’, ’ File “/usr/lib/python3.4/traceback.py”, line 146, in _format_exception_iter\n for value, tb in values:\n’, ’ File “/usr/lib/python3.4/traceback.py”, line 125, in _iter_chain\n context = exc.context\n’, “AttributeError: ‘NoneType’ object has no attribute ‘context’\n”]’
Any help would be greatly appreciated!!
