'usb_path' option deprecated; removed; zigbee lights still unavailable
Hi, I have 2 Zigbee lights. Late yesterday they became “Unavailable”. The HA log said “The ‘usb_path’ option is deprecated, please remove it from your configuration”, and it mentioned Zigbee Home Automation (WARNING). I checked the community and checked my configuration.yaml file.
My configuration.yaml file was:
zha:
    usb_path: /dev/ttyUSB1
    database_path: /config/zigbee.db
I changed it to:
zha:
I restated several times (soft and hard reboot), and my 2 Zigbee lights are still unavailable.
I did check /config/.storage/core.config_entries and the zha device is there.
                "entry_id": "f886001ba53946bb88cbd1edc64b189a",
                "version": 2,
                "domain": "zha",
                "title": "HubZ Smart Home Controller, s/n: 31400282 - Silicon Labs",
                "data": {
                    "device": {
                        "baudrate": 57600,
                        "path": "/dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_31400282-if01-port0"
                    "radio_type": "ezsp"
                "options": {},
                "system_options": {
                    "disable_new_entities": false
                "source": "user",
                "connection_class": "local_push",
                "unique_id": null
Do I need to delete and reset up both Zigbee lights? How do I get HA to recognize them again? Any help would be very much appreciated. Thanks.
You don’t need to delete. Just go through the pairing process again and they will show up.
That did the trick. Thanks so much!
