USB ports no longer recognized when home assistant environment is loaded
I have an problem with my home assistant that my usb-ports aren’t recognized anymore when the home assistant is loaded. When doing a cold boot (unplug / replug adapter), at startup the usb ports ARE recognized. The light of my mouse flickers on and off, like when it’s connected to my pc. When the home assistant environment is loaded the ports aren’t recognized anymore. No keyboard control, Conbee II stick not working anymore.
For some reason it started working again, but then when i restarted the home assistant, the same problem occured.
Link to odroid forum topic.
https://forum.odroid.com/viewtopic.php?f=181&t=46884
