USB Stick in Network Modbus
My network cabinet is installed in the technical room in the basement. My Zigbee devices are on the ground floor. Unfortunately, the ZigBee network is not so good because I temporarily moved my Raspberry upstairs. But that’s not a nice solution, so I’m looking for a solution to make the Zigbee USB stick modbus-capable, so that I can integrate it into my network via LAN and later integrate it via the HA.
Does anyone know a working solution?
Best regards
Benedikt
depends a bit of the zigbee stick…
zigbee2mqtt supports ser2net
serial:
  port: tcp://192.168.10.18:321
but that doesn’t work with a conbee…
