They are all on the same device. The DATA disk. The point is to extend storage, not move all the DATA. That’s what that does right?
the point of the example was to show the existing ones in relation to the new one i wish for, the bold ones.
The reason i suggested it under the /usb instead of under /media is also that then add-ons can decide if they want to be exposed to /usb/Photos. If you would mount USB under /media you don’t have that choice.
It’s about hot pluggable USB sticks. e.g. a movie on it or photo’s or other data.
But i guess /media/usb/ would work too. Perhaps even better.
happens to the best of us. I manage to make myself look foolish most days
Mount Usb in HA.
That’s a good place to look if doesn’t work out of the box. I thought they updated it, but I am not really sure as I used that thread ages ago.
It doesn’t mount anywhere and they don’t show up.
It could be i broke something in the past when I tried mounting /dev/sda to /media/usb onetime.
might need reinstall OS.
This was the command i did back then.
mount /dev/sda /mnt/data/supervisor/media/usb2 rw,fmask=0022,dmaski=0022,codepage=437,iocharset=utf8,shortnae=mixed,errors=remount-ro 0 0
But that will not be there after a reboot right? That will have been gone after the 1st full reboot of the hardware.
unf… trying this now.
Example configuration.yaml entry
usb:
Still nothing.
I now have aa test tsick with 3 partitions, FAT, FAT32 and one NTFS. None of them bite so i don’t think that is it.
Log from supervisor sees it though:
22-08-06 15:09:49 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.ADD hardware /dev/bus/usb/001/012 - None
22-08-06 15:09:50 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.ADD hardware /dev/sg0 - None
22-08-06 15:09:50 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.ADD hardware /dev/bsg/3:0:0:0 - None
22-08-06 15:09:51 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.ADD hardware /dev/sda - /dev/disk/by-id/usb-_Freecom_Databar_07A91C0795C725E4-0:0
22-08-06 15:09:51 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.ADD hardware /dev/sda1 - /dev/disk/by-id/usb-_Freecom_Databar_07A91C0795C725E4-0:0-part1
22-08-06 15:09:51 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.ADD hardware /dev/sda2 - /dev/disk/by-id/usb-_Freecom_Databar_07A91C0795C725E4-0:0-part2
22-08-06 15:09:51 INFO (MainThread) [supervisor.hardware.monitor] Detecting HardwareAction.ADD hardware /dev/sda3 - /dev/disk/by-id/usb-_Freecom_Databar_07A91C0795C725E4-0:0-part3
yeah i read that also a long time ago but i felt it was a little too complex for me.
Maybe i should just bite the bullet.
But from what said earlier they should just show up.
But i will look trough it again. tx
I read it. Yeah… i don’t understand what it does.
So i rather not touch it. Sounds like something that can go horribly wrong
Edit: Okay i bit the bullet and did the udev thing. The one i picked worked it seems.
Gonna do one more shutdown and then an upgrade see if the behaviout persist.
