USB-UIRT with home-assistant
Hi, first post so kinda unsure where to put this.
Im trying to set up my USB-UIRT to my RPi3 and then use HA to control it.
This is what I have done and where im stuck,
Start by installing lirc
sudo apt-get install lirc
Run
dmesg | grep -i usb
generats this:
[  226.744926] usb 1-1.2: USB disconnect, device number 4
[  226.745326] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0`
[  228.001437] usb 1-1.2: new full-speed USB device number 6 using dwc_otg
[  228.121881] usb 1-1.2: New USB device found, idVendor=0403, idProduct=f850
[  228.121905] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[  228.121918] usb 1-1.2: Product: USB-UIRT
[  228.121930] usb 1-1.2: Manufacturer: FTDI
[  228.127791] ftdi_sio 1-1.2:1.0: FTDI USB Serial Device converter detected
[  228.128004] usb 1-1.2: Detected FT232RL
[  228.128990] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
My best guess is that the UIRT is at ttyUSB0.
Set up the config file to this:
# /etc/lirc/hardware.conf
# Arguments which will be used when launching lircd
LIRCD_ARGS="-d /dev/ttyUSB0"
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD=false
#Don't start irexec, even if a good config file seems to exist.
#START_IREXEC=false
#Try to load appropriate kernel modules
LOAD_MODULES=true
# Run "lircd --driver=help" for a list of supported drivers.
DRIVER="usb_urit_raw"
# usually /dev/lirc0 is the correct setting for systems using udev
DEVICE="/dev/ttyUSB0"
MODULES="lirc_rpi"
# Default configuration files for your hardware if any
LIRCD_CONF=""
LIRCMD_CONF=""
Run:
mode2 --driver=uirt2_raw --device=/dev/ttyUSB0
mode2: could not create lock file "/var/lock/LCK..ttyUSB0"
mode2: File exists
mode2: WARNING: detected stale lockfile /var/lock/LCK..ttyUSB0
mode2: WARNING: stale lockfile removed
mode2: uirt2_raw: checksum error
mode2: uirt2_raw: UIRT version 0905 ok
Press a button on my remote witch generate this:
space 1600
pulse 600
space 38500
pulse 8900
space 2150
pulse 600
Ive added my remote to the lircd.conf file:
#UNCONFIGURED
# To find out how to get a proper configuration file please read:
# /usr/share/doc/lirc/README.Debian
begin remote
  name  Yamaha_RAV302
  bits           16
  flags SPACE_ENC|CONST_LENGTH|REVERSE
  eps            30
  aeps          100
  header       8853  4532
  one           533  1714
  zero          533   589
  ptrail        533
  pre_data_bits   16
  pre_data       0x857A
  gap          107903
  toggle_bit      0
      begin codes
          KEY_CD                   0x000000000000EA15        #  Was: CD
        DTV/CBL         0x000000000000AB54
          KEY_DVD                  0x0000000000003EC1        #  Was: DVD
        MD/CD-R         0x00000000000036C9
          KEY_TUNER                0x000000000000E916        #  Was: TUNER
        V-AUX           0x000000000000AA55
          KEY_VCR                  0x000000000000F00F        #  Was: VCR
        MULTI_CH_IN     0x0000000000007887
        VCR2            0x000000000000EC13
        PHONO           0x000000000000EB14
        INPUT_MODE      0x0000000000003CC3
        SYSTEM_POWER    0x000000000000E21D
          KEY_SLEEP                0x000000000000E11E        #  Was: STANDBY
          KEY_VOLUMEUP             0x000000000000E51A        #  Was: VOL+
          KEY_VOLUMEDOWN           0x000000000000E41B        #  Was: VOL-
          KEY_MUTE                 0x000000000000E31C        #  Was: MUTE
          KEY_SLEEP                0x000000000000A857        #  Was: SLEEP
        SET_MENU        0x000000000000639C
          KEY_UP                   0x0000000000006798        #  Was: UP
          KEY_DOWN                 0x0000000000006699        #  Was: DOWN
          KEY_LEFT                 0x000000000000AC53        #  Was: LEFT
          KEY_RIGHT                0x000000000000AD52        #  Was: RIGHT
          KEY_ENTER                0x00000000000021DE        #  Was: ENTER
          KEY_ENTER                0x00000000000055AA        #  Was: RETURN
        TEST            0x0000000000007A85
        SPEAKERS_A      0x000000000000659A
        SPEAKERS_B      0x000000000000649B
          KEY_MENU                 0x0000000000003DC2        #  Was: OSD
        MAIN_SYSTEM_POWER       0x000000000000817E
        MAIN_STANDBY            0x000000000000807F
          KEY_CHANNELUP            0x00000000000EF10         #  Was: CH_UP
          KEY_CHANNELDOWN          0x00000000000EE11         #  Was: CH_DOWN
        A_B_CAT+        0x00000000000ED12
When I try to execute sudo irsend SEND_ONCE Yamaha_RAV302 KEY_SLEEP
i get this:
irsend: command failed: SEND_ONCE Yamaha_RAV302 KEY_SLEEP
irsend: hardware does not support sending
Anyone know what might be wrong here?
Thankful for any help.
