If a Kerui door sensor that shows up in RFLinkLoader :
2017-11-09 21:52:20 - 20;03;Eurodomest;ID=28a105;SWITCH=01;CMD=ON;
2017-11-09 21:52:26 - 20;04;Eurodomest;ID=28a105;SWITCH=00;CMD=OFF;
I’ve automatic_add: true in my configuration, but the sensor doesn’t show up in HA:
2017-11-09 23:44:16 INFO (MainThread) [homeassistant.components.rflink] Initiating Rflink connection
2017-11-09 23:44:16 INFO (MainThread) [homeassistant.components.rflink] Connected to Rflink
2017-11-09 23:44:16 DEBUG (MainThread) [rflink.protocol] connected
2017-11-09 23:44:17 DEBUG (MainThread) [rflink.protocol] received data: 20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R48;
2017-11-09 23:44:17 DEBUG (MainThread) [rflink.protocol] got packet: 20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R48;
2017-11-09 23:44:17 DEBUG (MainThread) [rflink.protocol] decoded packet: {'firmware': 'RFLink Gateway', 'version': '1.1', 'hardware': 'Nodo RadioFrequencyLink', 'revision': '48', 'protocol': 'unknown', 'node': 'gateway'}
2017-11-09 23:44:17 DEBUG (MainThread) [rflink.protocol] got event: {'firmware': 'RFLink Gateway', 'version': '1.1', 'hardware': 'Nodo RadioFrequencyLink', 'revision': '48', 'id': 'rflink'}
2017-11-09 23:44:17 DEBUG (MainThread) [homeassistant.components.rflink] event of type unknown: {'firmware': 'RFLink Gateway', 'version': '1.1', 'hardware': 'Nodo RadioFrequencyLink', 'revision': '48', 'id': 'rflink'}
2017-11-09 23:44:17 DEBUG (MainThread) [homeassistant.components.rflink] unhandled event of type: unknown
2017-11-10 06:51:31 ERROR (Thread-14) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2017-11-10 06:53:11 DEBUG (MainThread) [homeassistant.components.rflink] Sending command: UP to Rflink device: RTS_0F0F0F_0
2017-11-10 06:53:11 DEBUG (MainThread) [rflink.protocol] sending command: {'switch': '0', 'command': 'UP', 'protocol': 'RTS', 'id': '0F0F0F'}
2017-11-10 06:53:11 DEBUG (MainThread) [rflink.protocol] writing data: '10;RTS;0F0F0F;0;UP;\r\n'
2017-11-10 06:53:11 DEBUG (MainThread) [rflink.protocol] waiting for acknowledgement
2017-11-10 06:53:14 DEBUG (MainThread) [rflink.protocol] received data: 20;01;OK;
2017-11-10 06:53:14 DEBUG (MainThread) [rflink.protocol] got packet: 20;01;OK;
2017-11-10 06:53:14 DEBUG (MainThread) [rflink.protocol] decoded packet: {'ok': True, 'protocol': 'unknown', 'node': 'gateway'}
2017-11-10 06:53:14 DEBUG (MainThread) [rflink.protocol] command response: {'ok': True, 'protocol': 'unknown', 'node': 'gateway'}
2017-11-10 06:53:14 DEBUG (MainThread) [rflink.protocol] packet acknowledged
As you can see, the RTS cover I set up works fine.
Any one has an idea how I can use the data I got from the RFLinkLoader to use in HA as a door sensor/switch/light to trigger automation?
