Use Aeotec Z-Stick with Xiaomi Temperature & Motion Sensors?
I’ve been using Home Assistant for quite a while but have never really used ZigBee/Z-Wave devices so don’t know anything about them.
I was looking at getting some Xiaomi Temperature & Motion Sensors (as it seems you can buy them pretty cheaply), and I wondered if this USB Aeotec Z-Stick Gen5 would work with them via Home Assistant?
Or do I need to buy the ‘proper’ Xiaomi Gateway to get them working together?
I don’t believe they are Z-wave so you need the Xiaomi gateway.
The Z-Stick is Z-Wave, the Xiaomi are Zigbee. They can’t talk to each other.
Also, many Zigbee devices will only communicate with that brand’s Zigbee gateway, as I believe is the case with the Xiaomi Aqara devices.
You need the Xiaomi Gateway to have xiaomi zigbee products working
Ah, OK. Thanks for clearing that up.
