Hello!
Is it possible to use Airplay speakers (Airport Express with external speaker attached) or an Airplay enabled Sonsos speaker as TTS device from Home Assistant?
I have a HassOS installation on a Raspberry Pi 4B.
Thanks for answers!
Hello!
Thanks for answers!
I installed Forked-Daap and with the integration in Home Assistant I was able to use TTS through it to broadcast it to my AirPlay enabled receiver.
Ok. I will try if I can find something about forked-daap. Thank you!
This seems to be installing forked-daapd not on the Home Assistant Pi, correct?
Correct… just wanted to show you the potential. It is a great product. I used a docker container version and did install it side by side on my Home Assistant server.
Also readup on this thread: Forked-daapd and media player services some extra info in ref to forked-daap integration in HA. Notice the default VOLUME setting in the integration and TTS has a slight delay.
I used this container by the way https://docs.linuxserver.io/images/docker-daapd
Thanks for taking the time. I’m working on this for the next few days… slowly.
Asking OP, what did you end up doing for aiplay speakers. i have boston acoustics mc200air which goes to sleep on DLNA but can only be woken up using airplay. So i want to use airplay mode on the speaker instead of DLNA
