I have a simple Alexa routine, when triggered I would like to do certain things.
Is there a way to send a signal to HA via Alexa routine ?
Or is there a way to check if a Alexa routine was triggered ?
Create a template switch that does nothing
Use the switch on/off as trigger
Alexa can turn switch on/off
Or you can use an input_boolean
, they show up in Alexa too.
