Hi there,
I have set up a couple of custom intents which can be used to set my wall thermostats in different rooms and by that control my heating.
All this works well.
What I do not like that HA reads out the entity name in the response, such as:
The bathroom_heating_group_int0000003 has been set to 17degrees
This is really not nice. Now I could go in and rename those entities to something more friendly but before doing this, and having to edit config files and potentially automations as well I wondered whether there is a way to tell HA to use an alias name rather than the entity name, when it responds?
I haven’t tested it for this particular case, but you can assign an alias in the Voice Assistant settings by clicking “Expose” at the top then clicking on the entity.
I have a power-switch that’s exposed to voice assistant, and I also gave it an alias “Centre Fan”. But when I successfully say “Hey Jarvis” then “Turn on centre fan”, he responds “Turned on the switch”. I’d like him to say “Turned on the centre fan”.
You will not be able to change the response for built-in intents locally, as far as I know
Translation participants discuss the best practices for interacting with a voice assistant on github, but unfortunately it is impossible to please everyone.
You can also open a discussion on this issue.
For custom sentences, this format is not relevant, since the response is part of the intent script.
That’s disappointing as it’s bad enough that for accessibility there is no option to add start and stop sounds to the voice input like I have for all my Google Home devices.
This is also a feature I would love to see. All my device/entity names are in Dutch, aliases in English because Voice Assistant is way better in English, so responses would preferably be in English as well, but are using the Dutch names.
Ideally you can set a default alias for the Assistant responses or a multi language naming system should be introduced, so the Voice Assistant picks the Device/Entity name in the language of the Assistant.
