Hi, I’ve got 2 home assistant instances running and are accessible by the Internet.
Is it possible to expose one entity and automation by the other instance?
So for instance I’ve got an entity named ‘remote.22_philips_uhd_android_tv’ on home assistant instance 2
I would like to control that entity on a card in home assistant instance 1.
I do not think it is possible directly (perhaps using some MQTT trick). So I’d go for webhooks integration. E.g. on instance 1 pressing the button on card would trigger webhook send to instance 2. On instance 2 there would be automation responding to this webhook, that would interact with your remote.
A webhook might work. The automation can pass data and a variable to a webhook that can be recievec by the other instance.
MY vacation home informs me when there is something on the camera to look at, for instance. It pings me, I go to the camera feed. That’s driven by a webhook along with the camera to look at.
person_detected:
description: "Person Detected so Notify Home"
trace:
stored_traces: 10
fields:
message:
description: This will set the message
required: false
example: "My person's lost"
selector:
text:
multiline: true
type: text
variables:
# Define variable data and provide defaults 4 your system)
message: "My person's lost"
sequence:
- action: shell_command.person_detected
data: { "message": "{{message}}" }
- action: notify.message_dad
message: "{{ message }} movement"
This is the shell command:
person_detected: curl -X POST -H 'Content-type:application/json' --data '{"message":"I spy a {{message}} person"}' https://hooks.nabu.casa/gAAAAABjAndAllTheLongWebHookStringHere=
