I have a automation that should one of my smoke detectors go off. The lights in my house come on, Two zwave sirens sound and alexa in every room announces a emergency.
We had a false alarm the other night and this highlighted a problem. Its difficult to silence everything which at 4:30am is not ideal.
I have bought a fibaro button with the Idea of using it to stop the smoke alarm automation and silence alexa and the sirens.
I’m not sure how to implement this though. Has anyone done this or something similar who can point me in the right direction?
The “emergency” automation will turn on the sirens et al.
You will have to create a new automation, triggered by the button, that will turn off everything the first one turned on.
The problem I have is the automation that is activated when a smoke detector has a repeat until condition.
If I change the state of the ‘alarm_group’ to off it is turned back on by the detector that is activated.
I really need a way to stop the actions of the automation. I tried the stop automation which does what I need at the expence of disabling the fire_action script.
I’m trying the input boolean method and it is not working. Could someone look at this bit of code for any mistakes. group.fire_alarm will have a state of on. Pressing the button sets the state of the input_boolean.fire_action_button to on
To be sure (and because of negative reliability experiences with the fibaro button): Does the button work with a most simple automation, e.g. pressing the button turns on a light?
