Use Case for M5Stack Atom Lite
Dumb old me bought a M5Stack Atom Liite instead of the echo from ebay. It took two week to get here and when I arrived I realized , duh. Oops. So It was $15 and I don’t want to send it back I need a good use case for it. I could always use the button for some kind of automation. And the LED can be set to a different color as a silent alerts.
What are some good use cases for the atom liteI bought by accident. I have 7 of other ESPHOME device so pretty familiar with that programing and integration into HASS, just need some ideas.
I will source the Atom echo from another vendor as it looks like they are on backorder.
Maybe you can use it as a Bluetooth proxy
That is all I use them for now. Their WiFi is really weak, so they are close to access points.
What kind of devices do you use that need the Bluetooth proxy. Temp sensors or something like that.
Do not feel bad, I just got my very own ATOMS3 Lite … duh !!!
I also need a good use case to use the dam thing.
Did you find a good use of it ? If you did please share here if you can… Thanks
Anybody with a good case to use the ATOMS3 Lite other than a Bluetooth beacon ???
They work ok for ESPresense base stations I’ve found
