Use config-template-card with default entity tap action
Hi everyone,
I’m using the config-template-card, a good card for me.
The sample change the theme of the internal card (type: entity) according to the temperature and works fine.
My current problem is:
The default tap action of internal card (type: entity) doesn’t show the history popup using config-template-card.
Do you have any idea to solve this?
      - type: custom:config-template-card
        variables:
          getTheme: |
            value => {
              if (value <= 0 || value >= 35) {
                return 'Dark - Red';
              if (value <= 10 || value >= 30) {
                  return 'Dark - Orange';
              return 'Dark - Green';
          currentValue: states['sensor.wx_temperatura'].state
        entities:
          - sensor.wx_temperature
        card:
          type: entity
          entity:
          name:
            - ds
          state_color: true
          theme: ${ getTheme(currentValue) }
Then please post in the dedicated "config-template-card" thread.
Knowledge placed in one place instead of 100500 threads; you will get answers faster.
The “name” option does not support a list.
Use “name: ds” instead.
Does not work with "sensor" domain.
The Entity card DOES NOT support tap_action (which is strange for me too).
Hi again,
this entity card supports tap_action, if you write the entity without list, the history appears on click.
entity: sensor.wx_temperature
Thanks for your comments.
Correct, this is what I missed.
