I’m trying HA for the second time. I switched from domoticz to HA for a couple of days a while back butnduentovthe difficulty levelvi went back to domoticz. Now I’m back again this time for good. Domoticz it too buggy. However a simple task in domoticz is impossible for me here. I want to sent a message with telegram, that works. I just want to add the current time in the message. I cannot get it to work. How do you use the system time.
now() returns a datetime object string like 2022-10-18 10:23:45.6789-01:00. If that isn’t want you want, you can use a number of methods to format the output the way you need.
Yes. That worked. Is there a way I can find all the possible commands and syntaxes. In domoticz it is auto filled in so you can easily browse through all of them.
