Hi All,
I was wondering if this question ever popped up. Have not found anything on the forum. One such question appeared on the mysensors forum:
https://forum.mysensors.org/topic/8991/sensor-naming-problem
Was wondering if having an option to use description of a sensor as its name could be considered as a new feature? What are the pros/cons of having such an option. I would like to get some of your thoughts on that as I was thinking to add this functionality and send a patch.
EDIT: to give some background.
In my case, the reason behind this is that I’ve got a bunch of relay switches with push buttons grouped as sensors and my sketch does a pretty good job of naming them properly. The setup would be instant when using those description names instead of manually renaming them, creating yet another layer of name conversion.
Regards,
Bartek
