Use device configuration to change z-wave parameter
I try to update the parameters of a z-wave device by using the user interface (see screenshot).
But the field of three parameters can’t be seen completely, the value is hidden because it looks like the input field is too narrow.
I installed the latest software releases.
Has anyone an idea how to edit the parameters?
Thanks H.
Try decreasing the width of the browser window, making it vary narrow, as if you were on a mobile device (or use a mobile device). The text boxes should shift to the next line and get wider as you decrease the window width.
Relevant issue: https://github.com/home-assistant/frontend/issues/13124
Thanks!
I tried everything, searched a lot.
So simple if one knows the solution.
