Use door sensor to toggle the switch
Hi, i have a door sensor installed in my room as well as sonoff wall switch. My room door is always closed and i want to setup an automation to switch on the light when i enter the room and switch it off when i leave the room.
Basically i want like this,
Door sensor state : close ->open (enter the room)->close , turn on light
Door sensor state : close-> open (leave the room) ->close, turn off the light
Something like sending a logic high/low to toggle the switch. However, i can’t figure it out how can i setup the automation in such way. Any advice?
hi
I use the below for my bathroom, if you change out the senor name and the light or switch id for on. The reverse for turning it off.
- alias: 'Motion Sensor Bathroom Lights On'
    platform: state
    entity_id: binary_sensor.visonic_z06
    to: 'on'
    service: light.turn_on
    entity_id: light.bathroom
Hi, i just figured out i can use switch.toggle instead of switch.on/off. Anyway, thanks for the suggestion.
If you’d rather the light turn on when you open the door I think something like this would work…
input_boolean:
room_occupied:
automation:
- alias: Turn Light and Occupation On
  initial_state: true
    - platform: state
      entity_id: sensor.door
      to: "on"
  condition:
  	- condition: state
  	  entity_id: switch.sonoff
  	  state: "off"
  	- condition: state
  	  entity_id: input_boolean.room_occupied
  	  state: "off"
    - service: switch.turn_on
- alias: Turn Occupation Off
  initial_state: true
    - platform: state
      to: "on"
  condition:
  	- condition: state
  	  state: "on"
  	- condition: state
  	  state: "on"
    - service: input_boolean.turn_off
- alias: Turn Light Off
  initial_state: true
    - platform: state
      to: "off"
  condition:
  	- condition: state
  	  state: "on"
  	- condition: state
  	  state: "off"
    - service: switch.turn_off
Could you share your configuration?
I can’t stop scratching my head over this simple but necessary automation when exiting the door
