RAW29
August 27, 2024, 2:52pm
1
I’m trying to create the following automation:
Ask Alexa to switch on a device e.g. Alexa, Switch on Fan
Alexa replies with “For how long?”
I reply with a duration, e.g. 3 minutes.
The duration spoken to Alexa is saved to a varible so I can use it in a script or automation.
If anyone can provide a basic example that would be really helpful.
thanks
mterry63
(Martin)
August 27, 2024, 4:28pm
2
RAW29
August 28, 2024, 8:32pm
3
Thanks for the link, it’s helped some but I’m struggling to get this working.
I have the Alexa Notification working and can capture the numeric response and have stored that in an Input Number.
The rest of the script now works using a manual value, but what I can’t work out is how to use the Number stored as a value further down the script.
The section of the script I need to use the value captured from Alexa is shown below where it is currently value: 4
- device_id: 822dfb7c32020a633da369c0dd25b62f
domain: number
entity_id: e5c2313044351983c4a1e778de165be6
type: set_value
value: 4
I’ve tried various different combinations but it always generates an error.
Examples I have tried:
domain: number
type: set_value
value: >-
{{ trigger.event.data.event_response| int(default=0) }}
domain: number
type: set_value
value: {{ states("input_number.microwave_run_time")|
int(default=0) }}
Error:
Can anyone provide the correct format for this please?
Script:
alias: Start Microwave
sequence:
- data: {}
action: alexa_media.update_last_called
- data_template:
text: for how may minutes?
event_id: actionable_notification_microwave
alexa_device: media_player.lounge_2
action: script.activate_alexa_actionable_notification
mode: single
Automation:
alias: Actionable - Start Microwave Full Power
description: ""
- platform: event
event_type: alexa_actionable_notification
event_data:
event_response_type: ResponseNumeric
condition: []
- action: input_number.set_value
metadata: {}
data_template:
value: "{{ trigger.event.data.event_response| int(default=0) }}"
entity_id: input_number.microwave_run_time
domain: select
entity_id: 49cd700ea40d009b9d12475457a4e425
type: select_option
option: Cooking.Oven.Program.Microwave.Max
domain: number
type: set_value
value: 4
domain: button
entity_id: dfdf41fd0fa9b71415c05c81ac8b89be
type: press
What does the trace of the automation show?
RAW29
August 28, 2024, 9:18pm
5
The trace is fine when I simply have the value set manually, but there is no trace as I’m unable to save the changes to the YAML as the error I posted earlier comes up when I try and save it.
The error is likely due to the lack of quotes around your template and the use of Device actions.
Device triggers, conditions, and actions are meant for basic function and do not always support advanced tools like templating in all fields. You should use an Entity-based number.set_value
action.
- action: number.set_value
value: "{{ states('input_number.microwave_run_time')|int(0) }}"
entity_id: number.YOUR_ENTITY_HERE
RAW29
August 28, 2024, 11:02pm
7
I’m assuming I have update this correctly based on your reply?
I’m still getting and error when I try and save the yaml
description: ""
- platform: event
event_data:
condition: []
metadata: {}
data_template:
domain: select
type: select_option
entity_id: number.383050426647027900_001_bsh_common_option_duration
domain: button
type: press
Sorry, I did the conversion quickly and messed up the keys, I have fixed it above.
