Action statements are a dictionary. You are trying to code it like it’s a list.
Neither one is correct, it needs an entity_id.
So like that, no, you can’t do it. I don’t know any way to make it work either.
I know you are likely using this in a blueprint, but it is really a data structure and template question, so I will switch up the category a bit for you to get the right eyes on it.
I want to use the entity_id from the action selector in a trigger so it doesn’t need to be entered multiple times. Right now, you define an action and then select the same entity again in an entity input. Trying to get rid of the redundant steps.
AFAIK, you’re basically going to be limited to Template triggers and Event triggers… but I am not much of a Blueprint creator so I haven’t tested the concept.
