Thank you for your appreciation!
I use flat USB cables and hide it under paper tape that matches the color and texture of the drywall.
Hello, are you okey with sharing your code for that frame. I live in sweden and liked your display.
Vänliga hälsningar Fredric
Sure! Here you go! Här kommer kod!
Is there any tool to like preview what to display and where? It’s ok to guess and update to see how it did go but would be neat to preview on the computer before updating the screen
How feasible would it be to create something like this that ran entirely off batteries?
I could do with a few of them around the house, however we’ve already renovated all the rooms and so I’ve got nowhere to plug them in, and whilst the picture frames look amazing, I don’t want to spoil that look by having cables trailing down the walls etc.
Obviously if they’re battery powered then they’ll want charging at some point, but I’m thinking that as it’s an e-Ink screen I might be able to get away with only charging it once a week (or maybe even less frequently!)
I cannot seem to find " HA-GTFS-RT" on the HACS respository. is it on different repository?
It’s probably possible if you don’t need to refresh the screen often. I’m not sure how power management on ESPHome works (e.g. to get the ESP chip to turn on by itself), so I’ll need to look it up.
In HACS under Integrations, there is a menu item (under the “…” at the top right) that allows you to add Custom Repositories. Add https://github.com/mark1foley/ha-gtfs-rt-v2 as an Integration in that dialog.
Hi Madelena.
I bought this display: Waveshare 7.5 inch E-Ink E-Paper Display - WS-13504
It coms with a hat, but i think it might be the wrong hat. Should i return this or can i somehow get this to work with another EPS32?
Hi Gert. Nice display. Is it possible that you would share your code? Best Sascha
Thanks Sascha,
You can find the code here:
Thanks Gert
Really nice
I see a lot of nice looking e-paper displays. But how does it look when the screen is refreshing?
My display blinks a couple of times when refreshing. It is so annoying that I don’t want to use it as planned
Here the same. Thats why I only refresh every half hour. Don’t know why it is not updating changes only like I should expect.
This is why I placed the display on a wall in my apartment that I don’t stare at often. You probably don’t want it to be in front of you next to your computer monitor, for example.
I feel like I must be missing something simple, but I can’t get my screen to update beyond the “Waiting for data…” prompt.
In the ESP logs for the online device, I just get the “No sensors updated - skipping display refresh.” output. I’ve found that the initial_data_received variable remains false, but even if I force a screen update when the "No sensors updated’ message appears (or even every minute), the screen updates but has no weather information - just null/blank values. (i’ve left out the transit info for the moment).
In Home Assistant, I’ve used some dashboard cards to verify that the weatherman_data template sensor has the expected weather data populated. It just doesn’t seem to be getting pushed to my ESP device.
What can I check to make sure the data is successfully passed to ESP?
How do you reset your recorded display refresh sensor?
I made a similar one, but it want it to be set to 0 one time a day, or count the number of refreshes/h.
Thanks for a inspiring project.
Regards
Gustav
Prompt ESP32 always works or goes to sleep with epapers. I just want to use without cable with independent battery
Can share configuration and template ?
well… answered my own question, and I was missing something simple.
this was my first time using ESPHome, and didn’t realize after adding the device in the ESPHome section, I also had to go to the Integrations dashboard and add it there as well…
