Thank you very much for the code! I’ll look into integrating it into my code.
I hope this will help mitigate the display issue somewhat.
Since these e-paper displays keep their display without power, why do we have to power them by USB?
How about these devices used in the supermarket without USB?
The supermarket epaper tags are powered by 2 x CR2450 cells for a relatively small screen, and since it only needs to be updated when price changes, it probably won’t update every day or even every week.
For weather in this project, it needs to be updated every hour or so; and for train times, it needs to be updated even more often every few minutes. I think, for weather, we can probably deep sleep ESPHome to make it possible to run this on a small Lipo battery, but for train times it’s probably not.
Is it possible to get a similar thing but touchscreen, to directly control stuff?
how could you input control this device directly without the touchscreen? or, would it be possible to have it touchscreen?
Based on the idea of GitHub - lmarzen/esp32-weather-epd: A low-power E-Paper weather display powered by an ESP32 microcontroller. Utilizes the OpenWeatherMap API.
I have created my battery & ESPHome driven display.
It provides some weather info, 5 day forecast, trash collection information and (if applicable) groceries delivery time slot.
Still have some space to fill
Created a 3D-printed case for the battery (3700 mAh LIPO) and ESP board (Firebeetle ESP32E).
It updates all its sensors every hour with a deep sleep in between. During the night is has a 8-hour deep sleep. Sensor data is coming from HA.
Hello everyone! First time when i sawthis project i was really like it. I bought display with control board, both arrived to me. I read everything here and probably i have same issue like liminalShane - the screen just doesn’t work. I was trying many variants of configurations, and nothing. Display even dont blink when i powered on
My display config:
display:
- platform: waveshare_epaper
cs_pin: GPIO15
dc_pin: GPIO27
busy_pin: GPIO25
reset_pin: GPIO26
model: 7.50inv2b
update_interval: never
reset_duration: 2ms
with this before
external_components:
- source:
type: git
url: https://github.com/atomicmike/esphome.git
ref: waveshare-color-2022.6
components: [waveshare_epaper]
I was trying another configuration before:
display:
cs_pin: GPIO15
dc_pin: GPIO27
busy_pin: GPIO25
reset_pin: GPIO26
model: 7.50in-bV2
reset_duration: 200ms
rotation: 90°
Switches on board in positions ‘A’ and ‘on’. I just wanna know what i am doing wrong with that.
What type of display and control board did you buy?
Waveshare 7,5 inch B display with red color i think. On the back side has V3 sticker. Control board - Waveshare ESP32 with cable
Check this configuration.
esp32:
board: esp32dev
framework:
type: Arduino
spi:
clk_pin: GPIO13
mosi_pin: GPIO14
display:
cs_pin: GPIO15
dc_pin: GPIO27
busy_pin: GPIO25
reset_pin: GPIO26
reset_duration: 2ms
model: 7.50inV2
update_interval: 60s
rotation: 90°
auto_clear_enabled: false
Wait for 1 minute to see if it refreshes.
If not, upload the demo project and check if the display is working.
Omg, thank you! I see the white noise, but im really happy, because i think that the display is broken
This is great! Do you know if it’s possible to like make the screen white with only a text in center that says something like “Sleep mode activated, see you in the mornin” or something to let one know it’s in it’s nighly sleep cycle? I tried it previously but I suck at coding this. HA i get but these devices don’t make sence to me
See my previous post. I just don’t understand why you’re using command line for that. Installing ESPHome is so easy.
esp32:
board: esp32dev
framework:
type: Arduino
So as I said, I’m new to all this. I’m using CLI because thats what I was instructed from the source I found and I’m using HA in docker which doesnt have add-ons. But I guess I need to find a way to get addons in order to use ESPHome
You can install the ESP board firmware by connecting it to your computer via a web browser.
https://web.esphome.io/
can you share your code?
Sure
Hello, I’m very inspired by this setup!
I’ve been trying to replicate the setup and get Waveshare ESP32 eInk Driver Board with a Waveshare 7.5 inch display to work. But to no avail.
I can successfully compile code to, and then connect via Wifi to the Waveshare ESp32 eInk Driver Board via ESPHome, but no luck getting the display to do anything, or refresh etc.
I’m not sure if there is something wrong with my code (see below for simple test code I’m using), dodgy hardware, or if I’ve wired it incorrectly (see images below)
Any pointers much appreciated, I’ve hit a wall!
Matt
esphome:
compile_process_limit: 1
esp32:
board: esp32dev
framework:
type: Arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: !secret weatherman_ap_ssid
password: !secret weatherman_ap_password
# Pins for Waveshare ePaper ESP Board
spi:
clk_pin: GPIO13
mosi_pin: GPIO14
# Now render everything on the ePaper screen.
display:
cs_pin: GPIO15
dc_pin: GPIO27
busy_pin: GPIO25
reset_pin: GPIO26
reset_duration: 2ms
model: 7.50inV2
rotation: 90°
