I am trying to use “homeassistant.login_failed” event to tigger an ios notification when a failed login occurs. The automation is configured and the notification is fired but only when I fire the event manually using developer options. If a failed login attempt occurs the notification is not received. How do i resolve this?
I am not seeing such an event as being available as standard, so where did you get that from?
It is not on the events listed on the developer tools for events and it is not listed on the Event page for HA
Maybe this can be used instead.
You’re right. It looks like it is no longer available after 2024.4.4 core update that was released today. Thanks
