Hi I haven’t used for loops before, so this is a first for me, I have parts of this working, but a bit stumped stumped as to how to finish this off.
What I’m looking to achieve is to receive a notification for each device that has low battery the and what type of battery/ies it takes.
Any help appreciated
alias: device_low_batt
- platform: time
at:
- '10:00:00'
- '17:00:00'
value_template: >-
{% set low_batt_device = states.sensor
| selectattr('attributes.device_class', 'eq', 'battery')
| selectattr("state", "is_number")
| selectattr("state", "<=", "20")
| rejectattr("entity_id", "search", ".*_zwave")
| rejectattr("entity_id", "search", ".*iphone*") | list %}
{{ low_batt_device | count > 0 }}
mode: parallel
- variables:
type_aa_x2: >-
{{ expand("sensor.wiser_roomstat_hallway_battery_level",
"sensor.wiser_itrv_bathroom_battery_level",
"sensor.wiser_itrv_bedroom_battery_level",
"sensor.wiser_itrv_living_room_battery_level")
| map(attribute="entity_id") | list }}
type_aa_x4: >-
{{ expand("sensor.cat_flap_battery_level")
type_cr123a: >-
{{ expand("sensor.hallway_smoke_detector_battery_level",
"sensor.living_room_smoke_detector_battery_level",
"sensor.front_door_lock_battery_level")
type_cr1632: >-
{{ expand("sensor.mailbox_door_battery_level",
"sensor.wardrobe_door_battery_level")
type_cr2: >-
{{ expand("sensor.front_door_recessed_battery_level")
type_cr2032: >-
{{ expand("sensor.sideboard_battery_level",
"sensor.mailbox_vibration_battery_level",
"sensor.bath_shower_leak_battery_level",
"sensor.sink_taps_leak_battery_level",
"sensor.toilet_leak_battery_level",
"sensor.bathroom_fan_shortcut_button_battery_level",
"sensor.table_lamp_remote_battery_level",
"sensor.desk_lamp_remote_battery_level")
type_cr650: >-
{{ expand("sensor.bath_mixer_battery_level")
# Append friendly name with "sensor"
append_with_sensor: >-
"sensor.bath_mixer_battery_level",
"sensor.front_door_recessed_battery_level",
# Append friendly name with "thermostatic valve"
append_with_thermostatic_valve: >-
{{ expand("sensor.wiser_itrv_hallway_battery_level",
"sensor.wiser_itrv_kitchen_battery_level",
# Append friendly name with "thermostat"
append_with_thermostat: >-
{{ expand("sensor.wiser_roomstat_hallway_battery_level")
- service: notify.mobile_app_iphone
data_template:
title: Replace Battery
message:
{% for low_batt_device in states.sensor
| rejectattr("entity_id", "search", ".*iphone*") %}
{% if 0 <= low_batt_device.state | int(-1) %}
{% if low_batt_device in append_with_sensor %}
The {{ low_batt_device.attributes.friendly_name.split(" battery level")[0] }} sensor battery is at {{ low_batt_device.state }}%, the battery type is {% if low_batt_device in type_aa_x2 %}AA x2{% elif low_batt_device in type_aa_x4 %}AA x4{% elif low_batt_device in type_cr123a %}CR123A{% elif low_batt_device in type_cr1632 %}CR1632{% elif low_batt_device in type_cr2 %}CR2{% elif low_batt_device in type_cr2032 %}CR2032{% elif low_batt_device in type_cr650 %}CR650{% endif %}.
{% elif low_batt_device in append_with_thermostatic_valve %}
The {{ low_batt_device.attributes.friendly_name.split("Wiser iTRV ")[1].split(" Battery")[0] }} thermostatic valve battery is at {{ low_batt_device.state }}%, the battery type is {% if low_batt_device in type_aa_x2 %}AA x2{% elif low_batt_device in type_aa_x4 %}AA x4{% elif low_batt_device in type_cr123a %}CR123A{% elif low_batt_device in type_cr1632 %}CR1632{% elif low_batt_device in type_cr2 %}CR2{% elif low_batt_device in type_cr2032 %}CR2032{% elif low_batt_device in type_cr650 %}CR650{% endif %}.
{% elif low_batt_device in append_with_thermostat %}
The {{ low_batt_device.attributes.friendly_name.split("Wiser RoomStat ")[1].split(" Battery")[0] }} thermostat battery is at {{ low_batt_device.state }}%, the battery type is {% if low_batt_device in type_aa_x2 %}AA x2{% elif low_batt_device in type_aa_x4 %}AA x4{% elif low_batt_device in type_cr123a %}CR123A{% elif low_batt_device in type_cr1632 %}CR1632{% elif low_batt_device in type_cr2 %}CR2{% elif low_batt_device in type_cr2032 %}CR2032{% elif low_batt_device in type_cr650 %}CR650{% endif %}.
{% else %}
The {{ low_batt_device.attributes.friendly_name.name.split(" battery level")[0] }} battery is at {{ low_batt_device.state }}%, the battery type is {% if low_batt_device in type_aa_x2 %}AA x2{% elif low_batt_device in type_aa_x4 %}AA x4{% elif low_batt_device in type_cr123a %}CR123A{% elif low_batt_device in type_cr1632 %}CR1632{% elif low_batt_device in type_cr2 %}CR2{% elif low_batt_device in type_cr2032 %}CR2032{% elif low_batt_device in type_cr650 %}CR650{% endif %}.
{% endif %}
{% endif %}
{% endfor %}
