The new HA iOS has a lot of potential. I’m especially fond of the device tracker. But leaving the GPS on al the time is battery consuming, especially when the location is within a radius and not precise.
Many other apps use geofence when entering or leaving an area, it barely consumes any battery and works great.
No, I mean the HA iOS app. It uses GPS but I think it would be a good idea to test geofence for tracking of when a device is entering och exiting the “home area”.
Hey so the app doesn’t use GPS the way you think it does.
There are 3 situations in which we use your location:
You enter or exit a zone (this is a geofence)
Your location significantly changes
You hit the upload button to send a one time location update
In all situations, we use the Core Location framework to request your location. It uses a mix of GPS, Wifi, iBeacon and other sensors. GPS is the hardest hit on the battery. Only if your device hasn’t requested your location in a while will GPS be used, and that decision is up to the framework. I do not set anything that requires use of only GPS.
To be very clear, Home Assistant for iOS does not and will not constantly use your GPS. I will never implement such a function.
