Sorry for the lack of knowledge, I am new into this, just started as side project to Smartthings.
My initial plan was to use a docker container or synology as “man in the middle” to connect Xiaomi Home with Smarthings, as per link below, to control a roborock vacuum cleaner.
Question, it is possible to implement that guy app in HassOs? I would love to have all those functionalities in smartthings, and this is the only way. In HA is much easier, I’ve found scripts for all the controls.
Prerequisites
- SmartThings account
- Local server (Synology NAS, Raspberry Pi, Linux Server) with Docker installed
- Xiaomi Gateway (Only needed for Zigbee devices)
- Built-in bluetooth or dongle available on local server (Only needed for Bluetooth devices)
Docker Versions
Stable Versions
Docker tag
fison67/mi-connector:latest
fison67/mi-connector-arm:latest
Install Mi Connector API Server
Raspberry Pi
Docker must be installed and running before continuing the installation.
sudo mkdir /docker
sudo mkdir /docker/mi-connector
sudo chown -R pi:pi /docker
docker pull fison67/mi-connector-arm:latest
docker run -d --restart=always -v /docker/mi-connector:/config --name=mi-connector-arm --net=host fison67/mi-connector-arm:latest
